i just orderd msd coil #8227 from jegs, along with some 9mm FR wires and an RF1012, but neverind those, i was wondering how different from the stock coil is the MSD? will i not get the full potential out of it unless i get the billet dizzy and control box? i will be gappin my plugs to .55... or should i go with .60? i have the timing bumped already. here are the specs -
Primary Resistance: .44 ohms
Secondary Resistance: 3.1K ohms
Maximum Voltage: 48,000 volts
Inductance: 7 mH
Turns Ratio: 85:1
Peak Current: 300 mA
Spark Duration: 250uS
does jegs usually stick by their 1-2 delivery word and have my stuff on time? i was hoping id get it on my day off so i can play all day.
Ford Hoarder
78 & 92
I don't know about just the coil doing anything, it should. I noticed a differance when I did preety much the same thing only with the control box also.
Dont gap to 60, go .55 instead, gap em for a week, run it , let the compooter get used to it, then bump your timing to 13.5*
