93 eb bronco w/ 351. I want to start upgrading my ignition to msd stuff such as cap/rotor, iginition coil, wires and ignition control box in what order should I go? I heard that if you replace a stock iginition piece with an msd piece and u dont have other msg pieces u can cause damage or it flat out wont work..
Ford Hoarder
78 & 92
I do not know about causing damage, but i did all that at one time. once you have the box the other stuff isn't that much more. On they coil the sell a harness get that makes it super easy to put in, if the coil doesn't come with it
green ones make me horny
i dont think it will cause any damage, but there is no point in upgrading the coil if you are not going to get the stuff that is big enough to move the voltage. get your msd cap and rotor and some taylor wires, or ford racing 9mm wires. if you can afford the 130 bucks all at once just get it all at the same time
