1 - 4 of 4 Posts
Are those REAL?!?!
Do you have a pic of the Meter? What's it set on?
Most meters have 4 different OHMS scales- Rx1K Rx100 Rx10 Rx1 If you are on the Rx1K then 1.28 would be 1280 ohms. Of course they are meters with a needle and digital meters. If you have one with a needle (they are harder to read) you need to zero the needle to zero by shorting meter leads together and moving the thumb dial to move needle over 0 ohms. Rx10 would be a better scale than mult your reading times 10.
1 - 4 of 4 Posts
