‘95 Bronco XLT 5.0 E4OD, MAF——‘95 F150 XL 4.9 M5OD 4x4, SD
Hello all, I’ve made a few different threads over the past year or two for diagnosis of different things and that sort of stuff but I figure I’ll just make a build thread to consolidate my future progress since hopefully I’m not far from being functional.
So this is my ‘95 XLT. It has a MAF 302 with E4OD and shift-on-the-fly t-case. Currently about 158k mi.
So this thread will be a recap of the work I’ve done previously (as much as I can remember) and then picking up on new work. Many of the pictures are several years old.
This bronco was actually my first vehicle and I’ve held on to it even though it’s not been on the road in about 4yrs. It’s been in my family for probably around 15 I think and it’s been mine for right about 6.
Starting off the timeline here, before it was mine, it spent at least one maybe two extended stays in a mechanics lot waiting for what transmission work... off to a great start lol. My dad bought this bronco I believe from Georgia. And it’s been in KY ever since. It was my DD (2yrs ish) until I started working 45min from home then I bought a little Toyota echo gas sipper. It was good timing too because shortly after that I started getting trouble out of the bronco. It started stalling when you put it in gear... but only occasionally.
Long story short I had the transmission rebuilt in 2019 and it didn’t fix it so it was free (remember this for later) and then found a bad ecm. In the last year I was able to find a replacement ecm and then found that my ignition was failing also. So I’ve replaced the ICM and PIP. Cap, rotor, plugs and wires had been done not too long ago previously. Electronically now the truck runs well and operates and does not trip any CELs... but still got a stalling in gear when it gets warmed up, as well as super delayed reverse when it’s cool. So come to find out I hear that the trans shop I used was less than reputable. (This explains how long it took and being free should have been a sign)
So I’ve bought a used 96 or 7 e4od from a local OBS diesel guy for 100 bucks. When time allows we’ll do the swap. The replacement trans has 88k miles on it and he says it worked good when he pulled it from the f250 with 351. This fella is a friend and has built a truck for a relative of mine so I believe him to be trustworthy.
Other work I have done is as follows.
Recently: rear diff service and tone ring replacement (fix speedo wobble), front pads and rotors (fix soft brakes and shaking)
Not so recently: TPS replaced, IAC replaced, throttle body and intake manifold cleaned. Parking brake cable replacement.
Back when it was a DD: water pump and radiator replaced, motor flushed, short tube headers put on to replace busted cast iron manifolds. That’s all I can remember...
Cosmetically: really not much other than rubber inlay on console and dash and also front grill lights (both done when DD)
Thanks for reading and hopefully it’s worth following along!
