So after going to the Bronco Roundup in Florence Oregon and seeing my girls excitement with all the Broncos on the sand , we decided to dive headfirst into a new project. I picked up a 79 freewheeling Bronco, so far I've only found a little rust in the tailgate. Pretty good shape for it sitting outside for the last 14 years. Engine has been removed so I found a new 460 heart for it. I build patina style hot rods so this will be kind of the same flavor. I'm going to replace the decals on it but I will acid wash and clean up the body and leave the patina. Once the decals are replaced I will lock it all back in with a special clear coat I use 4 bare metal. Works really well. It's soaks into the paint and the steel and gives the illusion that it is brighter and shinier without the depth of a normal Automotive clear coat. We will be doing a 4 inch lift 35 along with new interior. I ordered the stuff you reseal the transfer case and the transmission while I have them out. Today I got started with cleanup. Started removing carpet and vacuuming up I also removed the seats. While I had it out front and it was pressure washing underneath of it I acid washed the front fender from the pictures you can see the difference. Hope you guys enjoy
