1 - 20 of 26 Posts
84 Bronco 5.3, 4l80e, NWF ecobox doubler, np205, 8.8 lsd ,44 ttb with dana 50 third
So i picked this old bull nose up for $1200 back in January with the plans of a weekend wheeler since we just had our 3rd child and 3 kids don't fit in the back of an Jeep CJ. And i have been slowly plugging away it with my oldest daughter who is 9. And she has name it "the Bronc". Its got the good 300-6 in it and the sm435 trans.
Since bringing it home i have pretty much got all of the wiring fixed minus on plug for the tail light harness which im going to end up cutting off and using a merti-pack 280 connector on it.
182290
Discussion Starter · #2 ·
So far i have put a 2 inch lift in the front it and gotten a set of 35s. Currently im in the middle of my rear disk brake swap. its a Ruffstuff Specialties 9 inch weld on kit. I went with the E-brake calipers. Im waiting for my rear brake hose to show up so i can finish it up
182293
182294
Discussion Starter · #3 · (Edited)
I decided that i hate V belts and swapped in serpentine belt set up off of a 90 truck on it. i also swapped in a sag pump from a van into it at the same time. but when i did this i found out that the radiators are different between broncos that have A/C and those that dont
182295
Discussion Starter · #4 · (Edited)
i looked for about 2 weeks for a radiator before i asked on here for help. then was pointed in the direction of a small block chevy radiator since the inlet and outlet are different for 300-6 trucks vs the v8 trucks. i found that goes into a k5 blazer that would fit. it was about 2 inches shorter than the core suppert. so i made new mounts and threw it in. (thanks BigBlue94)
182296
182297
Discussion Starter · #7 · (Edited)
i also removed the feed back carb junk since the ecm was dead. i went back with a dura spark distributor and a gm HEI module. it runs and starts so much better now. i went with the dura spark because when i put the efi on it i will need to use the dura spark distributor with the advances locked out. so i think this brings me up too current times. there is some rust repair that has been dont that i dont have pictures of. i have also pulled the full hvac system out of an 85 f150 that i will be swapping in because im to fat not to have ac lol
That's a lot of thin, rusted metal on the floors by the seat belt. I just did a bunch of similar repairs on my 86, & it looks like you know what you're doing, so I'm sure it will turn out just fine. I used a new rear sill on mine, but I have seen people use a 3x5 sq steel tube as well, which gives you a nice 5" flat to weld the bed floor to. Keep up the good work!
Discussion Starter · #9 ·
im putting a cage in it to help strengthen the body back up. i went with 2x6 in the back of it because its what i had at the house. im also planning on 5 point harnesses for the front two seats because the lower seat belt mount is gone and i have no idea what it looks like or how the OEM had it. its defiantly a labor of love on this one. but its next stop was the junkyard if i didnt buy it.
ate lug
88 + 96 broncos, 96 F250
Woah thats a lot of sheetmetal repair.
Im interested in that TBI stuff- so youre going to swap a GM TBI onto the 300? Does the TB just swap in place of the carb or are there aftermarket adapters or something? Ive never heard of doing this before, but it actually sounds like a pretty easy/clever way to get EFI.
Discussion Starter · #11 ·
i will need to buy a one barrel to tbi adapter and the lock out the mechanical advance in the dura spark distributor and let the ecm control both fuel and timing. if you want to do some reading on it i recommend binderpanet.com. they have a whole sub forum for putting gm tbi on things it never came. including a 1200cc minicooper. its about as simple as system as you can get. and a lot cheaper the the aftermarket efi options on the market. i have put it on a few amc motors for guys in the Jeep club i used to run with.
Discussion Starter · #12 · (Edited)
well needed up take the day of work. so i worked on the bronco. i pulled the radiator core support to repair it. but its toast and i just ordered a new on instead. but in the process of pulling it i poked a hole in the brand new aluminum radiator while i was at it. :mad: but i should be able to solder it back up. so i figured while everything was out of my way and i was waiting for parts id start on my winch bumper. the base plate is a piece 8 inch channel iron and the side plates are 3/8 thick. i figured over killing it was a good idea being i have a 15000 pound hydraulic winch i picked up cheap from a buddy over a year ago.
edit: fixed the radiator. soldered the hole closed. and also go a call that my cage will be here monday
182462
182461
Discussion Starter · #13 ·
got the new core support put in and some work done on the bumper this weekend. i used 1/8 inch plate to cover the center section. the outer parts will be 1/4 inch plate.
182589
Discussion Starter · #14 ·
well i finally worked on the bronco again since mother nature wasnt trying to kill me this weekend. i got the rear part of the cage tacked in and the floor board tacked in.
184084
Discussion Starter · #15 ·
well im doing a bad thing thats going to ruffle some feathers. im getting ready to stick a 5.3 ls motor in the bronco. so here is the last picture of it in the truck. hoping to have it out by tomorrow. and start on the new motor mounts.
Motor vehicle Vehicle Automotive tire Automotive lighting Automotive fuel system
Discussion Starter · #17 ·
i would have loved to do a coyote but every still wants an arm and a leg for them. plus i had the 5.3 and 4l80 laying around from a jeep rock crawler i parted out.
1981 Bronco, 4.9L, ZF5, NP208, Detroit Truetracs, 3.55 gears, 31" Wranglers front and rear
I'll be interested in seeing your results. Probably not something I would do, but you have it on hand and it's your Bronco! I'll be sending you a PM about your Sag unit.
Reactions: diver14_98
Not ruffling my feathers. It's yours put whatever you want in it. If it makes you happy then that is all that matters. The 5.3L LS truck motor has turned out to be one of the most reliable engines. I especially like the 99-04 series. Anything before they added AFM and DBW throttle bodies. Hell I want to swap one of the new Ford 7.3L gas motors but they are still pricey at the salvage yard, and will be for a few more years.
Discussion Starter · #20 ·
well its out. getting ready to drop the trans and the rest of the old exhaust. then its time to get rid of the factory motor mounts.
Light Motor vehicle Car Automotive tire Automotive fuel system
1 - 20 of 26 Posts
