Forgot to mention I stopped by the machine shop again. I've been trying to catch the owner as he's in and out often and he's often the only one who knows anything about what's going on in the shop. I got some great news though, the manufacturer that makes the stroker kit he ordered for me sent him an email saying that that particular stroker kit is no longer being produced. Nice!
It's a good thing I stop by on occasion, because communication at this shop is very poor. They do good work, but they won't tell you about it. Anyway, he did say that he started piecing together a stroker kit himself, so maybe he would have told me at the point he had sourced everything and it was in house, I don't know. He said they had some 30 over pistons on the shelf already from a previous build that ended up not using them and that he was able to order a Scat crank and some rods that were in stock.
I have a balancer already, as I was originally going to do just a 302 and was gathering parts, so I may be able to use that now. Before that I was just going to have mine sitting on the shelf as the stroker kit comes balanced with its own balancer. So, I'd need a flexplate on top of that and then they could balance the whole assembly.
He said "second week of April" when I asked him when I could bring in my parts as I'm trying to clear things out and they're taking up a lot of space. He wants everything to be in house at the same time so he can slap it all together at once. Not sure if it'll really happen that way, but we'll see. I still need to take him my balancer so he can check it out and be sure it'll work with the crank he ordered.
And then lastly, I spent a large chunk of Monday before work putting together all my welding stuff in order to weld on the tray for my camper's propane tanks. It took a lot longer than expected as I wasn't satisfied with the way the cheap HF welding cart was supposed to be bolted together using no washers and the holes in everything are nearly the same size as the bolts' heads. I know it's cheap, but come on. So, a trip to the hardware store.
I set the welder on the cart, went through the literature, and made sure I put everything where it's supposed to go. Again, I'm new to welding, who would've known that you set it up where the ground cable plugs into the positive side (flux core wire). I would've screwed that up. Thanks, instructions. The welder comes setup out of the box for .030 wire. The wire I grabbed way back when I bought everything is .035. So, a trip to HF to get either .030 wire or to get .035 tips. They had absolutely no (flux core) .030 wire, so I just got the .035 tips and then went home and finished setting things up. At this point, hopefully it's just plug it in and make some arcs. Tomorrow!
