Hello all, i ran a search but could not really come up with anyone with the same problems. i have a 96xl fullsize with the 5.0 and 5 speed. the truck is stock except for 31's the truck also has 59,000 miles on it (all road miles). anyway when i am driving slowly in 1st like trying to park in a lot, my front end creeks and pops slightly while turning tight. if my windows are down i cant really nitice it but if you are outside or have the windows down you can hear it pretty clear. i have greased the front end, (at ford zerks) but that did not seam to matter. i have also done a visual inspection under.
could this be my spindal needle bearings? or maybe the ttb pivot points? i have checked the radius arm mounting rivits and bushings, they both look good, is there a spray greese i can use on those pivot bushings and the radius arms?
i appriciate all the help you may be able to provide.
thanks in advance
BYRON
thanks in advance
BYRON
