96 XLT
Without warning Thursday my driver side bearings started making some god awful noise and started causing some vibrations. I pulled over immediately and had it towed home. Cracked it open today.
Got the hub off (manual supreme mile markers) and I knew it was going to be bad. The bearing cage was ****led behind the hub body and in front of the spindle lock nuts. Picked it out with a few of the bearing rollers.
Got the lock nuts off and the goddamn hub assembly won't budge. I went and rented a slide hammer...still can't get it to move. I don't have an acetylene torch so I got my little propane torch, tried it heat it and then use the slide hammer nothing. The rotor will still spin....although not easily.
How the hell am I going to get the hub off the spindle?
