No such luck anywhere near me, might just have to stick with an oem replacement for the time beingFor an 84 bronco with v-belts, you need to find a 75-84 econoline (75-87 for 351w and 460, 75-86 for 300 I6) in the junkyard. Pull the brackets and pump out as an assembly. Rebuild kits are 15 bucks, but you need a pulley removal/install tool. A standard high pressure hose for an econoline of said years is all you need to complete the install. That hose is identical for 302, 351, and 460. Then fill it with ATF and bleed the air out.
