1 - 20 of 31 Posts
Engineer
Extended Radius arms (no 56k)
Radius arms in progress...
Stock arms boxed in and prepped for extensions
Tube extensions
Square extension/support
*Note at this point parts might not be cut to length*
Engineer
Discussion Starter · #2 ·
Some more pics
Tube cut to length
Square tube cut to length
Welding time, I'll be back in an hour
looks good, about time you made some progress. Better hurry only 3 weeks left. tick tock tick tock
Engineer
One arm done. Yes I need to screw the heim in
heres some pictures of his welding work.
Past Bronco Owner
Wow, what's that about 18" of extension? Looks good.
Former owner of Shadofax
That's what I was thinking. I don't know about all that, not knocking the work, just the length. I think it's adding more likelyhood of bending. There is only so much to be gained by lengthening unless there are going to be other major suspension mods. These look like they would be overkill for the superflexy superflex coils. And anything less will just make these a hindrance.
What is the overall length? They look like they would be a good 8" longer than the cage arms.
scrounger extrordinaire
just for info, the bent and twisted extensions are only 11" long. its too late now, but did you look to see where these are going to have to mount to the frame?
Sway Is My Fan Club.
Am I the only girl that came in here expecting to see some pics of somebody's strong sexy arms?
I feel cheated. However those radius arms look good. Good job. :thumbup
Engineer
Discussion Starter · #12 ·
It doesnt matter where they mount on the frame. I'm building a tranny crossmember for my ZF that's going to have built in radius arm brackets and a full t-case skid plate. So it's not too late.
got both arms done yet? then get that axle under it so you can locate your mounting points for the coil buckets (unless those are done) and radius arms. then in liek 4 more years at this pace it will be done haha.
Nice work.....I am thinking I have alot more searching ahead before I start buying parts for my D60 Swap.....Oh Mel is was sorta thinking the same things about arms...This one scarred my brain
Past Bronco Owner
Don't worry that didn't happen with the jump. It was from dragging the broken axle about 2 miles that caused the left side to bend like that.
I don't think boxing it in would have helped much under the stress they were in.
Engineer
Discussion Starter · #17 · (Edited)
Alright another pic a comparison, mine to stock.
I dont know where the bushing mounts on the original arm but you can see mine's about 10 inches longer.
This is what they looked like when I got them
Thanks for the pics.....retract what I said earlier about length, they are actually perfect....they are about 1.5" less than cage arms.
Engineer
Discussion Starter · #19 ·
Yeah they look pretty good or at least the one that is done does. I wish it wasnt 90 outside. More pics coming later when the axle is ready to go in under the truck
That's what I like about Shadowfax, he's objective!!!!
1 - 20 of 31 Posts
