I'm about to commence a custom remote tune by Adam Marrer of Pops Racing on my '92 Bronco w/MAF conversion and E4OD (see below for all of my details) and wanted to know if anyone is interested in me documenting or posting pictures of any aspect of the process or the equipment on this forum. I'm a complete dumbass in regard to this tuning stuff (Adam's going to be holding my hand throughout) so expect me to say lots of inane and idiotic things.
I'm using a Moates Quarterhorse tuner/datalogger and an Innovate wideband sensor on the hardware side, and Binary Editor running on my MacBook Pro (through Parallels) on the software side. I'm welding two additional O2 bungs (even though I only need one additional bung) for the WB on my Bassani Y-pipe - one right at the collector, and one in place of my AIR pipe which I no longer use, and have temporarily closed up using a cork. That way I can pick the best location for the WB sensor and also use the bung plugs (that just sounds wrong..) to permanently seal off both openings when done. I think the best spot is the collector, but the hole for the AIR tube (6" further downstream) is just so convenient.
From what I understand, I'll be hooking everything up and datalogging what's going on with the Bronco while completing specific driving scenarios, and then emailing the data back to Adam. He will then make changes to my tune based upon the data and I will redo the driving/datalogging exercise. This may or may not get repeated (again, I am clueless here) and finally, when he feels he's got it just right, he'll burn me a tune onto a chip. I think! It's all supposed to work brilliantly... More info about Adam and remote tuning here:
http://eectuning.org/forums/viewtopic.php?f=3&t=18136
Again, let me know if you are interested in me documenting any specific areas of the process or the equipment.
S
Ford Racing 6007-XE3 302 Motor in '92 Ford Bronco w/E4OD Tranny
Ford Racing 9000-L58 Mass-Air Conv. with AKC0 Lightning EEC, 80mm MAS & 30 lb Injectors
Ford Racing 6250-E303 Cam
Ford Racing GT40X Aluminum Heads with Port & Polish and Comp Valve Job
Ford Racing Shorty Headers w/Bassani 3" Y-pipe, H-Flow Metallic Cat & Flowmaster Delta Force 10 muffler
Edelbrock Performer Truck EFI Intake Manifold
BBK Twin 56mm Throttle Body
Ford Racing Windage Tray
Ford Racing Double Roller Timing Chain
4.88 Gears on LS Diffs
35" ProComp Xtreme All Terrains on 17" Walker Evans Simlocks
S
