21 - 27 of 27 Posts
Driving Stuff Henry Built
You may find it does the same thing with a push bottom. Whack the solenoid when it’s sticking first. If the starter disengages when you do, you’ll know it’s not ignition related.
Cheers
I think he got the sticking/screaming starter thing solved in the post quoted below. If I read this thread correctly, his original problem was that it wouldn't crank. He then bypassed the NSS, but got the wires crossed up & had power from the reverse lights circuit feeding the solenoid which caused the starter to run on. He undid the crossed up NSS jumper, & now is back to a no crank issue. He has no voltage on the "S" wire to the solenoid, so is wanting the pushbutton to start the truck until he has a chance to track down the actual cause.
Yah had the wrong ones jumped. So figured out which is what and top switch is reverse and bottom nss. Just put the truck in reverse and watched which wires turned off the reverse lights. Now I jumped the proper ones and no go on engine start. So would I be looking at the relay on the fender or the fuse for the relay?
Discussion Starter #22
Yes exactly. Now what's my best power source for the push button? I'm guessing a positive wire that is only energized when the key is in the run position connected to a push button and the wire continues to the S post on the starter replay?
Discussion Starter #23
Ok so I ran a code reader just in case and I got code 67 O which says Neutral Pressure Switch circuit failure , circuit open (3.0L MAP, 3,0L MAF-SFI, 3.8L SFI)
Now I don't have an AOD in it anymore and have a C6 and I'm using a B&M Mega shifter with its own NSS. Not sure if this code has always been there since the swap since I only just checked it. Either way it wont start in N or in Park so I'm guessing its the Ignition Switch module thing on the column?
Discussion Starter #24
Ok well I installed a new ignition switch on the column, made sure it actuator went in all the way but no ****ing go. So not sure wtf can be the issue? Are there are electronics that require the NSS to have a signal before power is sent to the S wire from the ignition switch?
Also is the tumbler suppose to spring back a bit after letting go of the key when the truck starts? LOL don't ever remember how its suppose to act.
For now I need to get the push button going as I'm gonna need the truck here and there in the next two weeks. Which hot on key wire can I use for the push button to the S terminal?
Discussion Starter #25
Ok figure it out. I'm guessing actuator is bent. I didn't think of it as I replaced it a few years ago and couldn't imagine it bending or breaking so fast.Well it moves the rod but I guess the piece the rod sits in must have bent.
What I had to do it take the ignition switch off the column put the key to run and then use a screw driver to push the slider on the ignition switch all the way and the truck started :)
Now the fun part of taking apart the column once again.
21 - 27 of 27 Posts
