I was replacing the u joints on the rear drive shaft..... Then the cv joint came apart spilling the bearings everywhere... My question is. Is the cv joint the same as the front drive shaft? Because i have an extra front drive shaft.
what yr bronco you working on
if you fill in the truck info on your avatar we will always know what you are referring to
I don't Believe they interchange. IIRC the front doesn't have a double cardan. The double cardan joint is just 2 regular u joints and a centering ball. You can get a new centering ball from any parts store and rebuild it yourself.
