what are you trying to actually do?
Puts it were it doesnt go
i dont think there is a way in hell you will find that. you'd be better off by buying a long brass nipple, cutting the ends off and using a die to make the threads yourself. or get one of each fitting, cut each end off and weld it back together
Just curious. 1/8-27 NPT or FNPT is very similar in pitch to the M12 x 1.5T. Could you actually have a metric pipe thread? I ask because I've made this mistake in the past. Aside from that, I've never seen a stock fitting with female pipe to a male stud. Is it solid or does it have an ID? Sounds like a custom part for a specific item. What's the application, if you don't mind me asking?
