1 - 8 of 8 Posts
Ok, so I'm not sure if this fits here or not, but I thought some of you may know. I have a MAP sensor off of a '03+ Ford diesel. I think it is a 3 bar sensor, but 2 bar would be ok also. I am wanting to use it to datalog boost for my mustang. I am needing the pigtail that plugs into it. I checked fordfuelinjection.com but I don't think the one they sale would work. I checked local junk yards and the dealership but they only want to sell a large harness, much more than what I want to spend. Does anyone have any ideas as to where I could get one or if any one sees one in a junkyard, let me know. Also, if anyone can confirm it is a 3 bar or 2 bar, that would be some help as well.
Here is a pic of it
Thanks
Ford Motorcraft® (fordinstallersupport.com) - Wiring Pigtails Parts Catalog, Bronco/Ford truck & all Fords w/Ford part numbers & Illustrations
look like a WPT-282 which is also used in other applications.
and the MAP Sensor; could be CX-1961
CX-1961
Manifold Absolute Pressure (MAP)
Sensor
(2L1A-9F479AA)
LIGHT TRUCKS
FORD TRUCK .............................................2004-03
look in:
Ford Motorcraft® (fordinstallersupport.com) - Fuel & Emission Parts Catalog, Bronco/Ford truck & all Fords w/Ford part numbers, Illustrations, Carburetor Tag Numbers & Cross References
http://www.motorcraft.com/catalog.do?goto=fullline
shows it as;
Part No: CX1961
Desc: Map Sensor - Emission Parts"
Manufacturer: MOTORCRAFT
Years: 03 - 04
Applications: 20
App Years Make Model Engine Qty Per Vehicle
5 03-03 FORD TRUCK All Models V8-363 6.0L Dsl 1
1 04-04 FORD TRUCK F250 SUPER DUTY P/U V8-363 6.0L Dsl 1
1 04-04 FORD TRUCK F350 SUPER DUTY P/U V8-363 6.0L Dsl 1
1 04-04 FORD TRUCK F450 SUPER DUTY V8-363 6.0L Dsl 1
1 04-04 FORD TRUCK F550 SUPER DUTY V8-363 6.0L Dsl 1
1 04-04 FORD TRUCK EXCURSION V8-363 6.0L Dsl 1
http://www.trademotion.com/partlocator/index.cfm?action=getMultiSearchItems&siteid=213787&items=10
shows it as $48.25
This any help?
Maybe this is better?
:thumbup now, that's a pig tail!
And to all the Bronco ladies, peace and Humptiness forever
Diesel Gynachologist
i might have a harness with one on it I can cut off. Ill check.
yes its a 3 wire sesnor and connector if thats what you mean by "2 or 3 bar"
hmmmm, I could use a couple of those too :thumbup
Dustin, if you do, PM me on how much you want for it. BTW, it needs to be from a 99-04 turbo diesel I believe to fit. Also, the 2 or 3 bar doesn't refer to the electrical connections, it's a measure of the sensor's capacity. Basically some sensors measure up to 2 bar or up to 3 bar, where 1 bar is 14.7 psi. Although, I think the first bar is used for atmospheric pressure, and the psi after that is boost. I am only running 10psi right now, so a 2 bar sensor should work (up to 29.4psi including atmospheric pressure), but a 3 bar would be nice so I have room to grow.
1 - 8 of 8 Posts
