What'd you pay for the gear? I can get you one and a couple roll pins for $5 plus shipping cast(flat tappet cam, blue) or steel(roller cam, yellow), from Ford. You need to press out the roll pin and press the gear off the shaft. When you put it back on you have to make sure you press it on to the exact right spot. Don't drill until it's on the shaft or just drill one side of the gear. After the gear is on drill the rest of the way through the shaft and the other side of the gear(you probably won't get it lined up with the original holes. The book recommends drilling 90 deg from the original hole so you don't end up elongating the orignal hole..
