ok guys i got a another formed started but this is realy an emergency so i figured i put it here to incase anyone hasn't seen it yet heres the link http://fullsizebronco.com/forum/showthread.php?t=48353&page=3
i need diagrm for spark plug wires or pictures how they should be routed and which goes where i must have screwed somthihn up there because thats all i touched and it wont stop backfiring at idle its the worst jus constant poping
no sorry didnt realy identify the vehicle its the 5.0 but never mind sorry about that i figured it out, i thought it was going to be some kind of big deal and i was so sure i had everything routed corectly and nothing crossed i got out the haynes anyway and went back checked it out and i belive i had 7 and 8 backwards or maybe 7 8 and 5 i dont realy know i kind of coinfused my self but all is good now hasnt been runing this good in months if you guys want il put up a picture of the one plug and one wire that ****ed up over real good for the last few months
Misfiring/Pinging due to Improper Spark Plug Wire Routing for 5.0, Caused by Crossfire between #7 & #8 Spark Plug Wire by mightyautoparts.com
specifically: "The firing order of the
mentioned engine is such that number 7-8 cylinders
fire in succession. Routing those plug
wires in parallel will result in induction cross-
firing. In addition to a miss, spark plug electrode
deterioration of #8 plug will result..."
I have a few pics in my SF site;
best ones of distr routing:
http://www.supermotors.org/vehicles/registry/showmedia.php?id=141161
http://www.supermotors.org/vehicles/registry/showmedia.php?id=141160
etc.
Al S's label:
http://www.supermotors.org/clubs/superford/vehicles/registry/showmedia.php?id=104701
chk #8 for any fouling
& again, when you post the same Q in different topics or sections it makes it diff to know which t\section you'll check again for info
if you have the stock intake it is easy. it is cast into it. the cylinders are 1234- pass side and 5678 drivers side they will be listed on the intake runners.. then the firing order is listed just behind the thermastate housing. and most fords go counter clokwise...mike
there you go again, double posting and not bothering to read replies.
