1 - 4 of 4 Posts
I bought a 92 bronco with no motor or transmission. I want to swap in a ford 460 and c6 transmission. The engine I have is carburated. What transfer case would I need to use. Would the electric transfer case work or would I have to change it to a NP205 if so will it fit?
Any info would be great
Thanks
Rest in Peace Friend...
The Ford model transfer cases all share the same bolt pattern to mate up to the transmission adapter, so a NP 205, NP 208, B-W 13-45 or B-W 13-56 will bolt up. The main difference is in the type and design of shiter linkage for the t-case. That is usually specific to a ceretain tranny/t-case combo only. IF you want to use the electric-shift B-W 13-56, it will bolt up to the C6 adapter, and you will not need to worry about linkage issues. JSM84
just a thought you may want to find the computer and engine harnes out of a early 80's 3/4 or 1 ton ford that had a 460 in it. that 92 hanes is not going to match up and if you jerry rig it to make it work your gona get some supries
1 - 4 of 4 Posts
