ok so i finally got the motor running :shocked:thumbup . now here's the problems. dropped the dizzy in, definitely out 180*:doh0715: so flipped the dizzy and she started, i was amazed that all that i had done actually worked. but i went to start it from inside the truck and nothing. the starter won't engage unless i jump the solenoid, so new solenoid, same thing. thought maybe neutral safety switch so put it in neutral and didn't start, park didn't start. maybe ignition switch anyone know of a way to test?
crank trigger
something simple is amiss. something is either not hooked up or there is a broken wire. double check and get out your multimeter and do some testing. with all you have done right, it is some simple detail at this point.
ok i'm a little retarded, well the truck has been sitting for 6 months, i installed a kill switch that interupts the ignition switch. i forgot it was unhooked when i took the seats out for cleaning, i deserve a swift kick in the junk.
