1 - 2 of 2 Posts
do i still need the wedges in between the rear spring and axle. i just started putting a 6in lift from JBG with complete new leafs. while removing the old leafs i found one of the wedges cracked completely in half. the other is almost cracked through too. i went to advance auto and they dont have them.
Need a Bumper?
No but they do give about 3/4" of lift and are a 2 degree taper. With 6 inches of lift you should need about 6-8 degrees of taper to get your pinion angle right. Pull the crappy factory block and add a steel degree shim to your leaf pack. This is in the wrong section BTW and should go in the Newbe tech section. I'm sure it will get moved soon
1 - 2 of 2 Posts
