Yo Will,
"This sensor is used for misfire detection only. No affect on air/fuel calculations" by member rla2005
Harmonic Balancer W/ timing ring rebuild @ Damper Dudes in California| @
https://damperdudes.net/
Address 6180 Parallel Road, Anderson, CA 96007
●Need Help?Call: (800) 413-2673
The misfire sensor is an electromagnetic inductance coil similar in operation to a camshaft or crankshaft position sensor. A four-point stator, or pulse ring, located behind the crankshaft damper generates an electrical impulse in the sensor at each 90 degrees of rotation. The powertrain control module (PCM) (12A650) monitors the sensor pulses and flags any misfire events. When a specified number of misfires occur within a certain time frame, the powertrain control module
will alert the driver to the condition by turning on the malfunction indicator light (MIL).
No adjustment is cited by Ford.
96 Misfire Sensor, aka Crankshaft Position Sensor (CPS);
"Section 03-14: Engine Controls, Electronic
1996 Bronco/F-Series Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 05/18/2000
Removal:
Disconnect battery negative cable.
If engine is a V-8, proceed to next step.
Remove attaching screws and timing pointer.
Disconnect wiring and remove sensor.
Installation:
Follow removal procedures in reverse order.
Tighten attaching screws to 8-12 Nm (75-105 lb-in).
NOTE: Misfire sensor is not required on 49 State/Canada 7.5L engine. It is required on a 7.5L California engine.
NOTE: The timing pointer and misfire sensor are serviced separately on the 5.8L engine but not on the 5.0L engine where they are serviced as one assembly.
Remove two screw and washer assemblies and remove timing pointer and misfire sensor.
Connect misfire sensor electrical connector, if equipped.
Installation View, Misfire Sensor and Pulse Ring in attached diagram."
Welcome and congrats on acquiring the very best year Big Bronco known to men, women, children and canines!
ASAP, find out if speed control recall work, if equipped was completed. If you still have concerns about Recalls, please contact the Ford Customer Relationship Center:
US: 800-392-3673 | CA: 800-565-3673
Note: 3673 spells "FORD" on phone keys
For the hearing- or speech-impaired: Please contact the Telecommunication Relay Service by dialing 71
... have VIN ready.
"Summary: ON CERTAIN PICKUP TRUCKS, PASSENGER VEHICLES, SPORT UTILITY VEHICLES, AND MOTOR HOMES CHASSIS, THE SPEED CONTROL DEACTIVATION SWITCH MAY, UNDER CERTAIN CONDITIONS, LEAK INTERNALLY AND
THEN OVERHEAT, SMOKE, OR BURN. THIS COULD RESULT IN AN UNDERHOOD FIRE."
To confirm current status, use this guide by jowens1126 @
93 & 94-96 Cruise Control Recalls Repair
Note that the 93 recall is different than the 94-96 recall.
Here's the
1996 Bronco/F-Series Workshop Manual partial
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @
Owner Manuals | fleet.ford.com
96 Bronco Dealer Brochure @
https://www.ford.com/cmslibs/conten...sovers/bronco/pdf/96_Ford_Bronco_Brochure.pdf
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @
1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
For any Bronco questions or to chat about it's planned modifications, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as
Bronco and Ford Parts/Accessories (50 posts required to participate due to scammers who preyed on our members).
See How to add your 96s Signature @ Bronco Forum - Full Size Ford Bronco Forum by BigBlue 94
Baba Looey's Favorite FSB Links (lots and lots of tech links), includes "how do I get the tailgate glass to...", etc.
Our Sites'
FAQs, includes for example:
How To Save (Bookmark) Threads Or Posts
How To Search The Site
What is the Difference Between the Showcase and Gallery?
etc..
Try to find time to participate and vote in our Full-Size of the Month Contest & later in the year, Full-Size of the Year Contest @
Voting
You will get ideas by those competing. Prizes are awarded to the winner; a full spread in Bronco Driver Magazine is the top prize, in addition to a years subscription, once the article is submitted; and a years worth of premium FSB membership.
Al
