I have a '96 Bronco with a 351. I rebuilt the motor about a year ago. I put a little bigger cam bored it .030 over and polished the heads. These are the only things I did as far as performance mods to the engine. Ever since I have had a problem with the idle. I have looked for vacum leaks using propane, and water and could not find any leaks. I checked all the hoses with a hand held vacum pump and they all held a vacum.
I check the idle control with a snap-on scann tool and it check good. I also did a total scan and came up with no codes. Is this idle problem do to the engine mods. and will I just have to learn to deal with this? Or, is there something I have missed? :banghead
Charlie don't surf..
'92 Ford Bronco XLT
What type of idle problem is it? Low idle condition, high idle, stumble off the line?? Does your rig run well at speed?
