1 - 12 of 12 Posts
want too up grade my 94' 5.0efi bronco.but dont want to have too pull the block out.i want about 300-375hp.buget is around $2500.ive put top-in kits on my early broncos,but there not efi motors.just not sure on this efi motors.
Some assembly required!
Best piece of advise I can give you is to get over your not wanting to pull the block. 375 HP will definitely need work done on the bottom end, like a forged crank, and you're not going to do that with the motor in place. The bonus is that it will be way easier to swap the heads, cam, etc with the block out and on a stand.
well i may have to do what i can with block in. but thanks,but i still need so info on the efi motors,if i do change the heads,etc.do you have too get some kind of computer chip or something.
Age. Fac ut gaudeam
Start with this:
Then get these:
Stack them up like this:
Then get the saddle, and place on the tip top.
Ta-Da!
MARBLE GARGLER!
I agree, I have made cars and trucks MOVE with just bolt on parts, not to mention the better gas mileage-
2006 Lincoln Navigator
There is a recent article in Muscle Mustang and Fast Fords magazine on this very subject, i.e. more or less stock EFI 5.0L build from mild to wild. The Bronco EFI 5.0L is very similar to the mild engine they started with. You can see the stock E7 heads are the biggest limiting factor keeping the engine around 310 HP. The cam required to get there is a little on the wild side for a truck using Speed Density IMHO. Once they started using aftermarket heads the real pay off began.
You could get close to your lower HP goal using aftermarket heads, free flowing exhaust and some tuning.
Article URL: Modding Your 5.0 With Bolt-Ons And Beyond
1 - 12 of 12 Posts
