Hello,
Can someone list the Timken part numbers for the Axle Bearings and Timken Hub Seal for a 1996 Sterling Full-Float 10.25? It should be one inner and outer bearing (with races) per side, and one hub seal per side. Thanks
Man of endless projects
the outer bearing is SET38 and is race and cone. they come together
the inner bearing race and cone are sold seperatly. race is 3920. the cone can either be 3992 or 3994 and will interchange. 3992 is used on newer 94 and newer, the 3994 in on 94 and older. the 3994 is actually wider and i dont know why the change to a narrower bearing. some brands such as National only make the 3994 and sell them for both applications.
the hub seal is 11S34370T
I ordered the parts, thank you!
Reactions: GetBent4x4
