1 - 9 of 9 Posts
a renegade of funk
buddy just bought a boat and dumped it off in my back yard. guess he volunteered me to fix it
cant tell if its been "dewinterized" yet or not. and what to do to if it hasnt.
its a 1995 sea ray inboard mercruiser v-6
i guess any advice or info would be great
:scratchhe
Follow these steps for sure!
1. Buy a case of beer
2. Grab a bucket out of your garage.
3. Grab a beer out of your fridge
4. Fill it with large bills and a few rolls of quarters.
5. Go out to the boat and chuck the contents of the bucket at the boat.
6. Stand in aw.
7. Drink Beer
8. Repeat steps 3 through 7 until you are out of beer
9. Go inside
10. Repeat entire procedure every payday
penis
When was the last time it ran? does it actually float?
If it has been a few years a rebuild on the engine maybe in order, but if it doesn't float kinda pointless, I would take it to a launch and see if it floats, once you get that established go from there make sure everything works and functions porperly. Trims, gears, prop in good shape.
5. Go out to the Bronco and chuck the contents of the bucket at the Bronco.
6. Stand in aw.
7. Drink Beer
9. Go inside
Fixed for ya! :thumbup
RESIDENT ASSHOLE
By some muffs, hook them to your hose, place them over the water intake, and start it and let it run a while. You are only running the anti-freeze out so it doesn't pump into the lake.
You also want to check the exhaust manifolds for pipe plugs. These are sometimes left out to drain the block and exhaust, and to make sure anti-freeze is making it throughout the engine.
Other than that check the oil, and your all set.
Edit: On the 4.3's there may be a pipe plug in the block instead of the exhaust manifold.
I would pour some stabil anti ethanol fuel treatment in the gas as well.
1 - 9 of 9 Posts
