my dad called me the other day and said his trucks starter isnt engauging (2000 ranger 3.0 v6 2wd) i get to his work and tell him 2 turn it over so i can hear what its doing. the starter was just free spinning. i tow his truck home and take off the starter. to teeth were worn down a little so i told him to get a new one while i stayed and looked at the truck some more. well the flywheels teeth are worn down a little bit in a few places but not all around. he said that it happened out of the blue. it didnt make any kind of grinding noise just started spinning free. well anyway. after a hour of waiting and a list of stuff that i need to fix on his truck he comes back with a new starter. i bolt it up and the same thing happens. it just spins freely. there is no grinding noise. i made sure he got the right starter and im out of ideas. could the fly wheel of moved? there is more then enough meat on it to engauge the starter. btw this starter has maby 20k on, replaced along with the trans.
lol ive done this twice once with a high torque starter and once with my bronco's starter you either need to re build it or get a new one let me ask you a question hold the starter and try moving that gear and shaft like see if their is any play in it
[edit: unless their is a second engaging wire that needs to be installed but ive only ever had to put one on for high performance]
[edit: what brand is he going with and have him return the new one too and get a different brand]
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Bronco Forum - Full Size Ford Bronco Forum
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
