1 - 17 of 17 Posts
I just bought a 460 complete with transmission everything running and working. It is a 1977 model so it's got the crappy smog heads.
I've also got at my disposal a 1986(or close to it) 351 H.O. complete running with transmission.
I am building my 1965 galaxie (yeah it's not a bronco, but I'm happy with my bronco the way it is). What's the cheapest route to go here for getting a fairly impressive engine in my galaxie. I'm not looking for a demon, just something that'll push you back in the seat enough to sell it. Most of my restoration experience has been with stock drivetrains, so I don't know which of these would be cheaper to build to get the most power.
It would seem that the 460 would be my best choice since it's got more displacement, but I figured I'd ask yall you're opinions on it. I just made another post about the 460 heads, but any info I could get about them would be welcome as well.
well, a 390 might be my best bet, but since I've already got these 2 engines and both are totally build-able i can't see buying another one... Unless you've got a built 390 you'll trade me for both of these:toothless
it's going to take a lot of HP to make that heavy galaxie really sit you back much on acceleration... the 351HO still has shitty e7 heads so it's only going to make maybe 215horsepower... i'd rule that out. that 460 is going to make about the same power with it's shitty heads and low compression, maybe a tiny bit more torque...
IMO what i'd do is put in the 460, put a set of small chamber aftermarket heads on it, that way you can have good breathing and high compression both. and put a decent mild cam in there to compliment it. (something in the 1500 - 5500 range if you're running an auto with stock stall, maybe a little more aggressive if you're running a high stall, or stick shift). you could leave the bottom end of the 460 stock. expect 450+ horsepower if you do this option.. much, much better than either of the other options since it's over twice the power.
I have no idea what the housing is... It's mated to a C6 transmission now. I can't afford to drop 1200-1500 dollars on a set of heads right now, so all those fancy ones are out of the question. That money would be better spent elsewhere. I have the D3VE heads on it, so I'm thinking putting some flat or domed pistons in would increase my compression a little, and there is an awesome machine shop here that I'm sure will do my porting on the cheap.
I think replacing pistons and porting the heads on the 460 sounds like that might bet me where I want to be, maybe a cam and intake, but for now what do you guys think about pistons and porting on my existing d3ve heads?
how can you have no idea what the trans is? what engine is bolted to it right now, big or small? if there is no engine, measure and compare to the engines you have.
dome pistons and port work on your existing heads would get you good power too, but if you're bottom end is good right now, i think it would cost more than just a pair of off the shelf heads with small chambers.
maybe we're having mis-communication here... It is a C6 transmission, I don't think automatics have bell housings... at least not what I call a bell housing. I call a bell housing something that goes on a manual transmission that is removable.
I thought all factory 460's were big blocks? am I wrong there?
I'm not sure I understand the question is all.
I've got D3VE heads, and a D0VE intake on it.
351w and 460 use different bell housings.
and the C6 does not have a removable bell housing, nor is there a adaptor for small to big bell patterns.
oh, now I see where the miscommunication is...
Both my 460 and my 351H.O. have transmissions bolted on them. so no need to swap anything between the two...:thumbup
Banned
GOT THIS FROM 460FORD.COM
275-300HP 460ci
Intake System:
Holley 600-750 vacuum secondary
Edelbrock Performer (non-RPM) Intake Manifold
Cylinder Heads:
Heads can be D0VE or D3VE
(No Port work. Just good 3 angle valve job.)
Intake valve size 2.08
Exhaust valve size 1.65
Stock rockers.
Short Block:
Comp Cam Custom Spec Hydraulic flat tappet cam or equivalent
Based on the Xtreme Energy Hydraulic Series
Intake Lobe 5437 and Exhaust Lobe 5430
(Specs:240/250 adv., 196/[email protected], .476/.479 lift, 112 LSA)
Compression around 8.0:1
Stock crank
Stock rods
Standard volume oil pump
Stock oil pan
Exhaust:
Passenger cast-iron manifolds to dual 2.25" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
Summary:
87-octane. Horsepower peak at 4,100 rpm. Keep redline to 5000 rpm.
300-325HP 460ci
Intake System:
Holley 750 vacuum secondary
Edelbrock Performer (non-Rpm) Intake Manifold
Cylinder Heads:
Heads can be D0VE or D3VE with mild port job
(315-ish/180-ish cfm @.600)
Stock rockers.
Short Block:
Intake Lobe 5430 and Exhaust Lobe 5232
(Specs:250/268 adv., 206/[email protected], .479/.493. lift, 112 LSA)
Compression around 9.0:1
Stock crank
Stock rods
Stock oil pan
Exhaust:
Summary:
91 octane. Horsepower peak at 4,500 rpm. Keep redline to 5500 rpm.
325-350HP 460ci
Intake System:
Cylinder Heads:
Stock rockers
Short Block:
(Specs:250/268 adv., 206/[email protected], .479/.493. lift, 110 LSA)
Stock crank
Stock rods
Stock oil pan
Exhaust:
1.75" headers to dual 2.5" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
Summary:
350-375HP 460ci
Intake System:
Edelbrock Performer Rpm Intake Manifold
Cylinder Heads:
Stock rockers.
Short Block:
Stock crank
Stock rods
Stock oil pan
Exhaust:
Summary:
91 octane. Keep redline to 5500 rpm.
375-400HP 460ci
Intake System:
Cylinder Heads:
Heads can be D0VE or D3VE with mild port job and port match
Stock rockers.
Short Block:
Comp Cam XE262H Hydraulic flat tappet cam or equivalent
(Specs:262/270 adv., 218/[email protected], .513/.520, 110 LSA)
Compression around 9:0:1
Stock crank
Stock rods with good bolts
Stock oil pan with windage tray
Exhaust:
Summary:
91-octane. Keep redline to 6000 rpm.
Banned
400-425HP 460ci
Intake System:
750cfm Holley DP professionally calibrated for your application
Cylinder Heads:
D0VE heads with mild port job and chambers polished
(315ish/180-ish cfm flow @.600)
Stock rockers.
Short Block:
Compression around 9.5:1
Stock crank
Exhaust:
1 7/8" headers to dual 2.5" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
Summary:
425-450HP 460ci
Intake System:
Cylinder Heads:
D0VE head with mild port job, chambers polished, and port match
Roller rockers.
Short Block:
Intake Lobe 5443 and Exhaust Lobe 5203
(Specs:268/280 adv., 224/[email protected], .524/.544 lift, 110 LSA)
Stock crank
Exhaust:
Summary:
450-475HP 460ci
Intake System:
Cylinder Heads:
D0VE head with mild port job, chambers polished and port match
Roller rockers.
Short Block:
Comp Cam XE274H Hydraulic flat tappet cam or equivalent
(Specs:274/286 adv., 230/[email protected], .562/.565, 110 LSA)
Stock crank
Eagle I-beam rods
High volume oil pump
Deepened oil pan with windage tray
Exhaust:
Summary:
91-octane. Keep redline to 6500 rpm.
475-500HP 460ciIntake System:
750cfm Holley DP Carb professionally calibrated for your application
Cylinder Heads:
D0VE heads with larger valves, port job, chambers polished and port match
(330-ish/190-ish cfm flow @.600)
Intake valve size increased to 2.19
Exhaust valve size increased to 1.76
Roller rockers.
Short Block:
Compression at 9.8:1
Stock crank
Eagle I-beam rods
Exhaust:
1 7/8" headers to dual 3" pipes with H-pipe. Good flowing 3" Magnaflow mufflers or equivalent.
Summary:
91 octane. Keep redline to 6500 rpm.
500-525HP 460ci
Intake System:
Cylinder Heads:
TFS street heads with mild clean-up
Roller rockers.
Short Block:
Compression around 10.0:1
Stock crank
Eagle I-beam rods
Exhaust:
Summary:
Banned
525-550HP 460ciIntake System:
850cfm Holley DP Carb professionally calibrated
Cylinder Heads:
Roller rockers.
Short Block:
Comp Cam XE284H Hydraulic flat tappet cam or equivalent
(Specs:284/296 adv., 240/[email protected], .584/.588, 110 LSA)
Stock crank
Eagle I-beam
Exhaust:
Summary:
550-575HP 460ci
Intake System:
950cfm Holley DP Carb professionally calibrated
Weiand Stealth Standard Port Intake Manifold
Cylinder Heads:
TFS street heads with mild clean-up and chambers polished
Roller rockers.
Short Block:
Comp Cam 34-652-5 solid flat tappet cam or equivalent
(Specs:294/304 adv., 256/[email protected], .589/.615, 108 LSA)
Compression around 10.5:1
Stock crank
Scat H-beam rods
Block oiling mods
Exhaust:
Summary:
91-octane. Keep redline to 7000 rpm.
575-600HP 460ci
Intake System:
Edelbrock 4150 Victor Intake ported
Cylinder Heads:
TFS street heads with mild clean-up and Victor port match
Roller rockers.
Stud girdle.
Short Block:
Comp Cam XR280R-10 solid roller street cam
(Specs: 280/286 adv., 242/[email protected], .657/.664 lift, 110 LSA)
Compression around 12.0:1
Stock crank
Scat H-beam rods
Block oiling mods
Exhaust:
Summary:
100-octane. Horsepower peak at 6,000 rpm. Keep redline to 7000 rpm.
600-625HP 460ci
Intake System:
1050 cfm Holley Dominator Carb professionally calibrated
Edelbrock Dominator Victor Intake ported
Cylinder Heads:
TFS street heads with mild clean-up Victor port match
Roller rockers.
Stud girdle.
Short Block:
Comp Cam XR286R-10 solid roller street cam
(Specs: 286/292 adv., 248/[email protected], .664/.671 lift, 110 LSA)
Stock crank
Scat H-beam rods
Block oiling mods
Exhaust:
Summary:
100-octane. Horsepower peak at 6,200 rpm. Keep redline to 7000 rpm.
625-650HP 460ci
Intake System:
1050cfm Holley Dominator Carb professionally calibrated for your application
Edelbrock Victor Dominator Intake ported
Cylinder Heads:
TFS street heads with mild clean-up with Victor port match.
Roller rockers.
Stud girdle.
Short Block:
Comp Cam XR292R-10 solid roller street cam
(Specs: 292/298 adv., 254/[email protected], .671/.678 lift, 110 LSA)
Stock crank
Scat H-beam rods with upgraded bolts
Block oiling mods
Exhaust:
Summary:
100-octane. Horsepower peak at 6,500 rpm. Keep redline to 7200 rpm.
650-675HP 460ci
Intake System:
1150cfm Holley Dominator Carb professionally calibrated
Cylinder Heads:
TFS street heads with port job and Victor port match
Roller rockers.
Stud girdle.
Short Block:
Comp Cam custom spec solid roller cam or equivalent
Xtreme Energy Street Rollers on intake and CR Series Rollers on Exhaust
Lobe 4879 on intake and Lobe 4682 on exhaust
(Specs:310/311 adv., 272/[email protected], .698/.683 lift, 110 LSA)
Stock crank
Block oiling mods
Deepened and fully baffled oil pan with windage tray
Exhaust:
Summary:
100-octane. Horsepower peak at 6,700 rpm. Keep redline to 7200 rpm
Banned
675-700HP 460ci
Intake System:
1150cfm Holley Dominator Carb professionally calibrated for your application
Cylinder Heads:
Kaase P51 heads with mild clean-up
Roller rockers.
Stud girdle.
Short Block:
Comp Cam Custom Spec solid roller cam or equivalent
Based on the High Torque .440 for intake and RT Series for exhaust
Intake Lobe 4240 and Exhaust Lobe 5203
(Specs:284/292 adv., 256/[email protected], .761/.743 lift, 108 LSA)
Stock crank
Block oiling mods
Exhaust:
2 1/8" headers to dual 3" pipes with H-pipe. Good flowing 3" Magnaflow mufflers or equivalent.
Summary:
100-octane. Horsepower peak at 6,700 rpm. Keep redline to 7200 rpm.
700-725HP 460ci
Intake System:
1250cfm Holley Dominator Carb professionally calibrated for your application
Cylinder Heads:
Kaase P51 heads with port job
Roller rockers.
Stud girdle.
Short Block:
Intake Lobe 4241 and Exhaust Lobe 4135
(Specs:288/298 adv., 260/[email protected], .761/.753 lift, 108 LSA)
Stock crank with aero and lightening mods
Scat H-beam rods with upgraded rod bolts
Block oiling mods
Block 4-bolted on center 3 caps
Exhaust:
2 1/8" headers to dual 3.5" pipes with H-pipe. Good flowing 3.5" Magnaflow mufflers or equivalent.
Summary:
100-octane. Keep redline to 7500 rpm.
725-750HP 460ci
Intake System:
Cylinder Heads:
Kaase P51 heads with full race port job
Roller rockers.
Stud girdle.
Short Block:
Intake Lobe 4245 and Exhaust Lobe 4137
(Specs:296/302 adv., 268/[email protected], .761/.753 lift, 108 LSA)
Custom pistons with compression around 12.5:1
Block oiling mods
Exhaust:
2 1/8" headers to dual 3.5" pipes with H-pipe. Good flowing 3.5-inch Magnaflow mufflers or equivalent.
Summary:
750-775HP 460ci
Intake System:
Edelbrock Victor Dominator Intake with full race port job and plenum mods
Cylinder Heads:
Roller rockers.
Stud girdle.
Short Block:
Intake Lobe 4252 and Exhaust Lobe 4138
(Specs:300/308 adv., 272/[email protected], .761/.753 lift, 108 LSA)
Custom pistons with compression around 13.0:1
Block oiling mods
Exhaust:
Summary:
105-octane. Keep redline to 7500 rpm.
775-800HP 460ci
Intake System:
Cylinder Heads:
Roller rockers.
Stud girdle.
Short Block:
Comp Cam 34-740-9 solid roller cam or equivalent
(Specs:313/319 adv., 275/[email protected], .806/.763, 110 LSA)
Custom pistons with compression around 14.0:1
BME aluminum rods or equivalent
Block oiling mods
Deepened and full baffled oil pan with windage tray
Exhaust:
2 1/8" headers to dual 3.5 " pipes with H-pipe. Good flowing 3.5" Magnaflow mufflers or equivalent.
Summary:
110 octane. Keep redline to 8000 rpm.
Banned
351M/400M and 460 will fit on a c6.
They both have the same type of bellhousing.
Discussion Starter #16
HOLY $HIT... thanks for all that info dr.
I am waiting for my membership to be approved on ford460.com
answered any question I might have had and some I didn't know to ask...:toothless
here's my mild 460 refresh
New cam
Duration at 050 inch Lift 218 int./228 exh.
Advertised Duration 276 int./286 exh.
Valve Lift with Factory Rocker Arm Ratio 0.503 int./0.503 exh. lift
Lobe Separation (degrees) 114
New timing chain (early version w/ straight up advance)
Rering (only because I had a broken ring, though).
stock bottom end w/ all new bearings
Mild port on D3Ve heads (maybe - haven't decided yet)
valve job (if I do the porting, I'll do this at the same time)
Holley 750/780 (I have both)
Perfomer intake
recurved Duraspark
MSD 6 box
new plugs and wires
There's no need to do a lot of this. You could easily get good power with just the timing chain and cam swap. If you're going to be selling it immediately, that's all I'd do.
1 - 17 of 17 Posts
