1 - 4 of 4 Posts
ok i have a 1995 EB i whant to put a 10 1/4 rear that i have no i know that a 1992 f250 has the ttb r the spindels the same that i can just swop then out so that i can have 8 lug all the way round
Age. Fac ut gaudeam
It's "swap"
"Ok, I have a 1995 EB, I want to put a 10 1/4 rear that I have in the Bronco. Now I know that a 1991 F250 would have the TTB and the Spindles are the same but can I simply swap them out so that it will allow me to have 8 lug all the way around?"
I think I translated it correctly...
Anyhow, enough of me being a douchecanoe...
Try using the "Search" function located below the main ad, among the many items on the menu such as "Quick Links"
G'Luck!
Side step it
Man I just re-read that 3 times & it pissed me off that I couldn't figure part of it out. Thanks for translating from 10 1/4 to F250 Andrew...I think that comes from too much texting.
I'm putting a 10.25 in my 96' and there is info on 8-lug swaps here under search plus, till you do a SAS up front you could use adapters, 5 to 8, as long as you're not too rough on it till you have the scratch! -Kevin-:thumbup
1 - 4 of 4 Posts
