I couldnt copy and paste the pictures, if you need them I can email them to you
LIGHT TRUCK: 1993 BRONCO
ISSUE:
A squeak condition may develop near the location of the seat belt "D" ring attachment on either side of the vehicle. This occurs because interference exists between the drip rail/roof/sill and the brace body side extension when assembled.
ACTION:
Modify the Roof Drip Sheet Metal to eliminate the interference which causes the squeak. Refer to the following procedure for service details.
NOTE: REPAIR BOTH SIDES OF THE VEHICLE TO PREVENT A REPEAT REPAIR.
SERVICE PROCEDURE FOR BASE VEHICLES
Remove seat belt "D" ring bolt and cover. Refer to Service Manual, Page 01-20A-7.
Using a 2.5" diameter hole saw, drill an access hole in the "B" pillar inside sheet metal 5" above "D" ring anchor nut, Figure 1.
Figure 1 - Article 93-15-13
Insert a large flat bladed screwdriver between the roof drip rail sheet metal at the point of interference, Figure 2.
Figure 2 - Article 93-15-13
Twist the screwdriver blade to separate the two parts in order to eliminate the interference.
Insert a rubber plug (385138-S) into the access hole, Figure 2.
Remove both sun visors and windshield garnish moulding.
Remove "A" pillar garnish mouldings and discard; retain the two (2) attaching screws (refer to Service Manual, Page 01-05A-13).
Remove roof garnish moulding (refer to Service Manual, Page 01-05A-14).
Install roof trim panel as shown in Figure 3 (refer to the parts block of this article for correct parts usage).
Figure 3 - Article 93-15-13
NOTE: NO FASTENERS ARE REQUIRED. PANEL IS HELD IN PLACE BY THE GARNISH MOULDINGS WHICH WERE PREVIOUSLY REMOVED.
Install the lock pillar trim panel with two (2) N800942-S58 drill point screws, Figure 2 (refer to the parts block of this article for correct parts usage).
Install windshield garnish moulding and sun visors.
Install "D" ring and cover as shown in Figure 2. Tighten attachment bolt to 30-40 N-m (22-30 lbs-ft).
SERVICE PROCEDURE FOR HIGH SERIES VEHICLES
Remove both sun visors, windshield garnish moulding, "A" pillar garnish mouldings and roof rear garnish moulding (refer to Service Manual Pages 01-05A-13 & 14).
Remove "D" ring attachment bolt and cover (refer to Service Manual, Page 01-20A-7).
Remove lock pillar trim panel, Figure 2.
Provide access hole and eliminate interference. Follow service procedure for base vehicles, Steps 2-5.
Replace the parts removed by following above steps 1-3 in reverse order. Tighten "D" ring attachment bolts to 30-40 N-m (22-30 lbs-ft).
PART NUMBER PART NAME
385138-S Rubber Plug Button (2 Required)
N801157-S2 Screw And Washer Assy. (2 Required, Base Vehicles Only, Pk./8)
N800942-S58 Screw - Drill Point
E9TZ-9851944-B3A Panel-Roof Trim - Crystal Blue
E8TZ-9851944-ABD Panel-Roof Trim - Scarlet
E9TZ-9851944-A6E Panel-Roof Trim - Granite
F2TZ-9851944-AAA Panel-Roof Trim - Medium Mocha
F2TZ-98281A32-A Panel-Body Lock Pillar Trim RH - Crystal Blue
F2TZ-98281A32-B Panel-Body Lock Pillar Trim RH - Granite
F2TZ-98281A32-C Panel-Body Lock Pillar Trim RH - Medium Mocha
F2TZ-98281A32-D Panel-Body Lock Pillar Trim RH - Scarlet
F2TZ-98281A33-A Panel-Body Lock Pillar Trim LH - Crystal Blue
F2TZ-98281A33-B Panel-Body Lock Pillar Trim LH - Granite
F2TZ-98281A33-C Panel-Body Lock Pillar Trim LH - Medium Mocha
F2TZ-98281A33-D Panel-Body Lock Pillar Trim LH - Scarlet
F2TZ-1503598-E Moulding-Front Body Pillar I/S RH - Crystal Blue
F2TZ-1503598-F Moulding-Front Body Pillar I/S RH - Granite
F2TZ-1503598-G Moulding-Front Body Pillar I/S RH - Medium Mocha
F2TZ-1503598-H Moulding-Front Body Pillar I/S RH - Scarlet
F2TZ-1503599-E Moulding-Front Body Pillar I/S LH - Crystal Blue
F2TZ-1503599-F Moulding-Front Body Pillar I/S LH - Granite
F4TZ-1503599-E Moulding-Front Body Pillar I/S LH - Medium Mocha
F2TZ-1503599-H Moulding-Front Body Pillar I/S LH - Scarlet
