Hey cuz you can get black oxide bolts fron ace hardware. Just take the old ones and match them up. Thats what i did.
I'm having a hard time picturing the whole acesory drive bracket. I did replace the stubs that went through the timing cover and water pump. The bracket that attaches to the power steering pump got new ones as did the belt tensioner but iirc that last one didnt bolt into the water pump.Did you guys also replace the stubs that go threw the timing cover, water pump and accesory drive bracket with bolts? If so what did you use as a spacer between the accesory bracket and water pump?
