1 - 3 of 3 Posts
hey guys i have just installed a 4inch RC lift on my 94 351 bronco and i have really bad negative camber. is it the coil springs causing this?
if it looks like this \---o-/ then you need to get it aligned
if it looks like this /---o-\ then you need to get it aligned
this alignment will cost you more than $100. if it doesn't then they didn't do it right.
you did install the TTB drop brackets right?
get a alignment the worse thing is your caster camber bushing will be maxed out, and you will need to buy a adjustable set i had to get 2.5 Moog caster bushings to get mine zeroed in good luck with it though....just get it aligned and look at the chart and make sure the tech knows what he is doing.
1 - 3 of 3 Posts
