yo,
What tranny?
If the shifter has a P-R-N-OD-D-1 pattern, the transmission must be an AOD
P-R-N-D-2-1 pattern is C 6
If it has an Overdrive Cancel Switch and a P-R-N-OD-2-1 shifter pattern, then it is equipped with an E4OD transmission
by Baumann Electronic Controls, LLC
See RockAuto.com
STANDARD MOTOR PRODUCTS Part # LS200T T-Series
w/ M.T.;
More Info
$5.75 $0.00 $5.75
w/ M.T.
More Info
$14.66 $0.00 $14.66
AIRTEX / WELLS Part # 1S5308 {#88923271, 88923453, D6RY7A247A, D6RY7A247B, F0VY7A247A, F409}
Trans. code AOT
More Info
$32.79 $0.00 $32.79
ORIGINAL ENGINE MANAGEMENT Part # 8805 {#E7TZ7A247B}
4WD; Trans. code C6 (Only 2 Remaining)
More Info
$35.79 $0.00 $35.79
STANDARD MOTOR PRODUCTS Part # NS54
2WD; w/ 4 Speed A.T.
More Info
$40.79 $0.00 $40.79
ORIGINAL ENGINE MANAGEMENT Part # 89013 {#D6RY7A247B}
Trans. code AOT; Automatic trans. (Only 2 Remaining)
More Info
$42.79 $0.00 $42.79
AIRTEX / WELLS Part # 1S5315 {#88923274, E6TZ7A247A, F419, ZZL019444}
Automatic trans.; 5 Pin Switch
More Info
$43.79 $0.00 $43.79
AIRTEX / WELLS Part # 1S5312 {#88923251, E7TZ7A247B, F416}
4WD; Trans. code C6; w/o Electric Shift
More Info
$43.79 $0.00 $43.79
MOTORCRAFT Part # SW2039 {#E6TZ7A247A}
4WD; Automatic trans.; 86GT-7A247-AA
More Info
$43.99 $0.00 $43.99
STANDARD MOTOR PRODUCTS Part # NS29
w/o Electric Shift; w/ 3 Speed A.T.
More Info
$44.79 $0.00 $44.79
MOTORCRAFT Part # SW1391 {#D6RY7A247B}
Automatic trans.; 74DT-7A247-GD
More Info
$44.79 $0.00 $44.79
STANDARD MOTOR PRODUCTS Part # NS44
AWD; w/ 4 Speed A.T.
More Info
$52.79 $0.00 $52.79
MOTORCRAFT Part # SW5978 {#F5TZ7A247AA}
F5TZ-7A247-A
More Info
$53.79 $0.00 $53.79
MOTORCRAFT Part # SW2136 {#E7TZ7A247B}
4WD; Trans. code C6; w/o Shift
More Info
$59.99 $0.00 $59.99
STANDARD MOTOR PRODUCTS Part # NS92
w/ Electric Shift; w/ 3 Speed A.T.
More Info
$61.79 $0.00 $61.79
What tranny?
See RockAuto.com
w/ M.T.;
More Info
$5.75 $0.00 $5.75
w/ M.T.
More Info
$14.66 $0.00 $14.66
Trans. code AOT
More Info
$32.79 $0.00 $32.79
More Info
$35.79 $0.00 $35.79
More Info
$40.79 $0.00 $40.79
More Info
$42.79 $0.00 $42.79
More Info
$43.79 $0.00 $43.79
More Info
$43.79 $0.00 $43.79
More Info
$43.99 $0.00 $43.99
More Info
$44.79 $0.00 $44.79
More Info
$44.79 $0.00 $44.79
More Info
$52.79 $0.00 $52.79
F5TZ-7A247-A
More Info
$53.79 $0.00 $53.79
More Info
$59.99 $0.00 $59.99
More Info
$61.79 $0.00 $61.79
