can someone tell me how to find out how much lift is on my truck and what kind of axles i have and gearing .it is a 84 bronco with a 4.9 inline six 4 speed the guy i bought it from said it was all changed but he did not know to what thanks if you can help
Rest in Peace Friend...
Can't help you with lift. If the axles are 5 lug, you probably have factory Ford 8.8" in the rear and Dand 44 in the front. The gear ratio if factory is probably 4.54. If factory, you will find an axle code on the safety compliance sticker which can be easily interpreted. Also, there will be a tag on the differential. A Ford 8.8" has a removable cover on the rear. If it is a 9" the bolts are on the front of the differential. Some pictures of the axles would be a great help since we can't see your truck.
Graydevil said:
A correction u ment 3.54 not 4.54. Are u shure u have a lift on it a pic would be helpful to see what u have..
Ford 8.8
Ford 9 inch
Right, fat fingers :banghead
My 84 has a 9 inch.
