1 - 3 of 3 Posts
Hi guys I just landed myself a gorgeous 95 with the 5.0L with a lot of new parts like ac compressor, water pump, alternator etc. I just found this page/forum. Would anyone have an idea why the ac will blow through the vents then then out the defrost? Usually on Max more often. I’m seeing stuff about vacuum lines etc. would that be a good
150635
place to start? Thanks everyone- Steven
Yo Steven,
Welcome and congrats on your fine looking 95!
For the HVAC Air Flow issue, see my Vacuum leak test in post #11 incl some jowens126 HVAC Control Panel pics/info @ https://www.fullsizebronco.com/threads/help-with-dtc-codes-and-idle.206824/
Includes, "Excess air leaking into the system will upset the fuel mixture and cause conditions such as rough idle, missing on acceleration, or burned valves. If the leak exists in an accessory unit, such as the power brake, the unit will not function correctly. Or Air Conditioning when in MAX mode may switch to Defrost."
➡➡➡ASAP⚠ find out if speed control, if equipped recall work completed by dealership. Call local dealer or register and view status @ https://owner.ford.com; or @ https://vinrcl.safercar.gov/vin/ ... have VIN ready.
See this guide by jowens1126 to confirm recall status @ https://www.fullsizebronco.com/forum/23-technical-write-ups/457065-93-94-96-cruise-control-recalls-repair.html#post6530073
Here is the 1995 Bronco Dealer Brochure
1995 Drivetrain, Powertrain Service Manual
https://drive.google.com/open?id=1M0M9m9vtiOxwy5wkJ203tlSTjwuWzcew
1995 Body, Chassis Service Manual
https://drive.google.com/open?id=1MJ0Li_e-Esufa-pnSR-edaQ9VD15SiMS
To switch between folder list & grid views, click the button to the right of the "DOWNLOAD ALL" button in the upper right corner of the window)by HawkDriver
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to view).
To save you time and for better responses, please fill out your Signature with location, year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. .
From the navigation, near the upper right-hand corner, click on your avatar and then select “Account Settings” from the drop down menu.
From your “Account Settings” page you will then see more navigation option of the left side. Select “Signature”.
Now you can simply enter your signature information in the text editor and click save.
Our Forum faqs @ https://www.fullsizebronco.com/help/faq/
Includes for example:
How To Upload Images To Posts & How to Use Search
See more tips!
Baba Looey's Favorite FSB Links (lots and lots of tech links) @ https://www.fullsizebronco.com/forum/21-noobie-bronco-tech-questions-flame-free-zone/131287-baba-looeys-favorite-fsb-links-lots-lots-tech-links.html
... Includes such as, How do I fix my back window?
Free registration for some wiring diagrams (86 through 96) and Technical Service Bulletins, (80 through 96) with Recalls, same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
➡ Try to find time to participate and VOTE in our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests @ https://www.fullsizebronco.com/forum/27-f-o-t-m-voting/
F.O.T.M. contests will be held in JANUARY, MARCH, MAY, JULY & SEPTEMBER. Each month in-between will be used for nominating contestants to run in the following Month.
Vote the on going Full-Size of the Year (F.O.T.Y.)⚠
Enjoy your 95 Steven!
Al
Al
1 - 3 of 3 Posts
