Gents,
Battery is 100%, but this week the truck would require a jump to get started. Fine once started. I suspected the alternator and/or starter relay so I replaced them both.
No, I didn't do the 3G swap. Just replaced it with an 80W. Next JY trip I'll look for a 3G. Truck will now start but then quickly dies. And when I do get it to run for a bit it's a low gurggle. When I step on the gas it dies. What could it be?
I feel confident that I wired everything up correctly, and reinstalled the serpentine belt right, but now I'm questioning myself. I did loosen the distributor bolt so I could turn it out of the way and get to the thermostat housing, but I turn it back when done. Did that screw up the timing and I need to reset?
While I was doing the alternator I decided to replace the thermostat. When I reinstalled the new gasket and housing there was a big leak. When I tried to torque it down tighter I cracked the housing. Now I've installed a new housing with a rubber O-ring around the bypass and main hoses. Still a small leak from the bottom of the housing. Any advice on fixing that too?
Gents,
What year do you have? I can't picture having to move the distributor bolt so you can get to the thermostat housing and I think your stalling issues are caused by the timing been thrown off. There are many good write ups on this site on how to check the timing so I would start there.
As far as the small leak from the bottom of the housing, put an uniform bead of sealant and your issues will go away. I used the Permatex stuff below and it's been leak free for 3 years..
I fixed it. Put some gasket sealer on the thermostat housing.
For the rough idle it was the distributor. I turned it back to the same spot got it started, then tweaked it slightly until the idle got back to normal. Belt was squeakythough so I replaced it for good measure since I have no idea how long it’s been on.
then while returning the belt tool to autozone the darn thing wouldn’t turn over for me to start up. Battery reads 100%. But my battery was a crappy value craft. 650 cold crank. Traded it for a duralast 750 cold crank and things started right up. Fingers crossed for no more starting issues. What battery do most guys run?
Battery Output depends on which battery you buy, the have premium, best , good lines... The general consensus is that Interstate is a premium brand at a decent price with a no nonsense warranty.
Once again I think I've fixed it. I bought new battery cables and re-did the alternator wiring so it is now above reproach. Then it started up nice. Then I took my dog to the lake and it wouldn't start. I could hear the starter whirring, but not making contact with the fly wheel. So it seems the real culprit may have been my POS starter all along. It was a reman one and was all autozone had when it died in the parking lot. So I removed the starter, returned it, and bought a brand new one for $30 bucks more. Started right up like a champ. Fingers crossed I finally have this electrical issue beat.
