Hey guys I am new to the site and have recently purchased a 94 FSB XLT with 4" lift and 35's. I have a done a little tlc on it but there are a few things I have questions about so here goes..
1. My rear window used to roll up/down fine but i washed it one day and hasnt worked since, could it be a short? the motor does not make a noise at all and the window is stuck in the up position so i cannot get the tailgate down. I took out the lock in the tailgate to have a key made for it and I saw the 2 buttons that im guessing roll the window up or down on the lock and pressed them, it still did not work so I am fairly sure it isnt the switches that are bad. I just went to autozone and bought a new window motor for it, but not an actuator. do you guys think that could just be the problem and maybe the old motor got wet? if so, can i stick a bag or some kind of plastic over the new motor to keep that from happening again? Is it possible that I need a new actuator or something else too and not just the motor? and if it is a short where is the most likely place and how do I check it?
2. When i bought the truck, the spare tire rack was off of it, but i have the swingarm part. i do not have the part that actually bolts to the truck, im guessing its some sort of quick release latch? the local junkyard did not have any FSB's, but i found a 1985 bronco 2 on craigslist the guy is parting out, it does have the swingarm on the back too, so my question is will that latch off the bronco 2 fit on my FSB tailgate? the swingarm looks the same to me so im thinking the latch could be as well.
3. I did not receive the owners manual for the truck. It has absolutely NO lighting on the inside, the bulbs are gone. I looked up the manual for the 1996 broncos and got the bulb #s off of there, but i know after 94 they went to a different over head console didnt they? so the bulbs could be different i just want to confirm this. Does anybody know which bulbs i need for the chrome dome light and the 2 map lights? how about the rear cargo light? and also the lights in the door panels?
4. The truck has no exhaust pipe on it at the time, it has the manifolds and stock y pipe i believe. I am wanting to run dual straight pipes out the back with no cats, is anyone running this and does it sound alright? right now it sounds like crap and is dumping right under the cab and is annoying.
5. My cruise control does not work, does anyone know a way to fix this or possibly replace it and for relatively cheap? or should i just go without it?
6. my dash panel around the speedometer is not really stuck on, just sitting there and my ignition is sort of jacked up, the U-shaped part the key goes in that you turn actually spins all the way around and sometimes will not let the key go in or out. the locksmith said my ignition has probably been changed? he said the front doors and ignition should of had the same key from the factory and the "round" key fits the glove box and tailgate? or is there actually 3 keys: 1 for front doors, 1 for ignition, and 1 for tailgate? this makes no sense to me why there would be 3 keys.. so if my ignition has been changed, can i fix it to where it does not move around and put back like it is supposed to be? and is there a way to make every single lock on the truck fit the same key? or instead have all the locks fit 2 keys instead of 3?
7. In the rear cargo area i have 2 cylinder shaped things sticking out of the floor by the tailgate, what are these? i dont see any real use for them and wondering if it came from the factory this way.
Lots of questions here i know, but any help would be GREATLY appreciated! hopefully when i get these few things fixed I will have a very nice bronco :rockon
