1990 351W E4OD
As some of you might know, last week I put a new Motorcraft long block in my Bronco. I’m having trouble getting it to run. It has a new starter, battery cables and a good Red top.
It seems like the motor is bound up or something. It cranks really slowly almost like it has a dead battery. The battery is at 12.5 volts. It will start and run for about 20 seconds then you have to give it more gas to keep it going. After another 5 seconds or so it knocks and shuts down. After that is will not even turn over until it sits around for an hour or so. Then it does the same thing.
With the timing advance dongle unplugged the timing is at 0 right now. With the tranny in N you can’t turn the engine by hand. Even with a 3’ cheater bar. It’s like it’s too tight.
For the few seconds it runs it does run well. The it goes kaput. Any ideas?
