Yup,GM has done that for a while. LS'sI can't figure out what I'm looking at spark-wise... COPs on top, connected to spark plugs on the side? Is that a thing?
Its a waste spark ignition system that uses 16 plugs, the coils on top fire 8 plugs and they have wires off of each to fire the other 8 plugs on the side of the head. Its an identical setup to the current 6.2 V8 thats been around since the 2010 raptor, which leads me to believe the 7.3 is just a enlarged version of the same engine.I can't figure out what I'm looking at spark-wise... COPs on top, connected to spark plugs on the side? Is that a thing?
Where does the spark originate from? It looked in the video like the COPs are just connected straight to the side plugs, but maybe I missed some wiring or it was just done that way for the cutaway illustration.Its a waste spark ignition system that uses 16 plugs, the coils on top fire 8 plugs and they have wires off of each to fire the other 8 plugs on the side of the head.
I think this is exactly about where it will be. Also pretty easy to get 1 hp/to per cubic inch, even using 1969 tech. So I think 450hp/500ft-lb is not out of the relm of possible/plausible. However even if capable of they will not rate it higher then the diesel. If you look at the ports and shape they very much so look like a lot of the aftermarket 429/460 heads.Please be in the 500+ ft/lb torque range :muscle071 :notworthy
I wonder how much the option for the engine will be?I think this is exactly about where it will be. Also pretty easy to get 1 hp/to per cubic inch, even using 1969 tech. So I think 450hp/500ft-lb is not out of the relm of possible/plausible. However even if capable of they will not rate it higher then the diesel. If you look at the ports and shape they very much so look like a lot of the aftermarket 429/460 heads.
If you listen to the whole thing the "engineer" also says most of it was overbuilt. Example the piston cooling nozzles, conrods and such. So I am sure that engine in a light duty application would likely be more then happy with 10-14 psi of boost on it.
The current 6.2l gasser does have the CNG prep option, I would think this 7.3 will get it too. On the 6.2 this adds hardened valves and special seats, and I am sure a few other things.
I personally think they are going cylinder deactivation route much like the LS engines on this, not the 2nd spark plug route.
