1 - 13 of 13 Posts
ok i have the E40d and had 4.88's put in and now it doesn't what to shift out of first till about 4000 rpm's. anybody else run into this? do i just need to find a programmer and reprogram it or is there a way to reset the computer?
thanks
are you sure the shop reinstalled the ring gear sensor?? its also possible they damaged it during the swap. did it shift similarly before the gears were put in, or just after????
First clue: Does your speedo work, and appear to be reasonably correct?
aka: kemicalburns
some thing must be wrong because mine never had a problem after the 4.88's
Ford Hoarder
78 & 92
I'd take it back and make the place fix em' where you had them installed at. That ain't right that now it doesn't work, has it always done it since you picked it up from them?
1 - 13 of 13 Posts
