I wanted to introduce myself and ask a few questions. I am form texas and just came across a great deal on a 96 bronco. I bought it dirt cheap, but it is going to need a little tuning up. The body is straight, the motor runs, but it needs a little tuning up to run great.
The truck is a 96 XL White, 5.0l engine, 4x4 and 105,000 miles. Anyways I hooked up a scan tool to it and got the following codes.
P1507- iIdle Air Control Under Speed Error
P0141-Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0401-Insufficient EGR Flow.
P1131-Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1.
P0304-Misfire Detected - Cylinders 4
P0175-System Too Rich - Bank No. 2
P0307-Misfire Detected- Cylinder 7
P0171-System Too Lean - Bank No. 1
Any suggestions where to start? I am pretty handy as a mechanic, but I don't want to just start replacing things that don't need replaced. Is there anything that could lead to all these errors, or do they need to be addressed separately. Thanks in advance
