1 - 11 of 11 Posts
Hello to all, I picked up a 79 project Bronco. Recently rebuilt 351m. It came on 33's and has a dual transfer case. It needs some sweet lovin, so now that i've said "Hi"...i'm headed over to the Newbie technical support pages and find out why I don't have low beams( only highs). I well post pics when i can.
1989 Eddie Bauer 5.8, C6, True Trac diffs, 4.56 gears, 4" C&T lift, 130A 3G Alt, 35" Grabber AT2s
Dimmer switch is probably bad. On the floor, constantly covered in mud, water, and salt. Replace it first.
welcome, best body style for bronco in my biased opinion!
before you waste a bunch of time, verify the low beams are not both burnt out!
Welcome, look forward to seeing some pictures of the best body style Bronco IMO (78-79)
Trusty rusty I should have read your post first!! I changed the dimmer switch and the headlight switch in the dash before I thought to test the lamps themselves. ..what are the odds both lamps went bad? Pretty darn good. Now I've got a couple extra parts to bounce around in the back.
glad you got it sorted
that happens more often than people think
I have seen it quite a bit over the years,not exactly the first thing you think of either
just like no starts, I have seen quite a few because the tank is out of gas,tons of parts get swapped and still no go
never trust a gauge,specially on a rig you just acquired
I'm part of the 79 club as well!! I've got a turn signal issue I'm looking into. It won't work if the headlights are on! Glad you got your issue solved.
Discussion Starter #11
I agree, best body. and i will give the 78 some love too. since my 79 has its round headlights.
1 - 11 of 11 Posts
