I've purchased a '96 Bronco that came from the factory with a 5.8L. Before I bought it, that engine had been replaced with a 5.0L.
In trying to get the vehicle to pass Missouri Emissions inspections, I've been chasing error codes throughout the exhaust system.
Replaced the O2 Sensors, the EGR Valve, the EGR Tube, the Vacuum purge valve, the Mass Air Flow Sensor, etc., etc.
One possible explanation that my ODB scanner has suggested is to replace the PCM.
The problem is, I can't seem to find anyone that can provide a "new" PCM for a vehicle that left the factory with a 5.8L and now has a 5.0L.
I'm not a mechanic and am learning as I go.
So, any help, guidance, suggestions, etc. are extremely welcome.
Thanks!
you're going to want to verify that the computer in your bronco is for a 96 / 302. there's a difference between "will it run" and "will it run at 100%".
i believe these are going to be the EEC / PCM codes you'll want to see on yours.
taken from a previous post by fireguy
1996 5.0L E4OD ML1-442 DDS0 F6PF-12A650-BPA
1996 5.0L E4OD ML1-442 TAD0 F6TF-12A650-JA
1996 5.0L E4OD ML1-442 TAD1 F6TF-12A650-JB
1996 5.0L E4OD ML1-442 TAD2 F6TF-12A650-JC
1996 5.0L E4OD ML1-442 TAD3 F6TF-12A650-JD
1996 5.0L E4OD ML1-442 TAD4 F6TF-12A650-JE
1996 5.0L E4OD ML1-442 TAD5 F6TF-12A650-JF
1996 5.0L E4OD ML1-442 BNE0 F6PF-12A650-BNA
1996 5.0L E4OD ML1-442 KQL0 F6PF-12A650-BRA
1996 5.0L E4OD ML1-442 VIV0 F6TF-12A650-BAA
1996 5.0L E4OD ML1-442 VIV1 F6TF-12A650-BAB
1996 5.0L E4OD ML1-442 BXZ0 F6TF-12A650-BLA
1996 5.0L E4OD ML1-442 BXZ2 F6TF-12A650-BLC
1996 5.0L E4OD ML1-442 FZA0 F6TF-12A650-BMA
1996 5.0L E4OD ML1-442 FZA2 F6TF-12A650-BMC
1996 5.0L E4OD ML1-442 SSM2 F6TF-12A650-BNC
1996 5.0L E4OD ML1-442 VEE0 F6TF-12A650-KA
1996 5.0L E4OD ML1-442 VEE1 F6TF-12A650-KB
1996 5.0L E4OD ML1-442 VEE2 F6TF-12A650-KC
1996 5.0L E4OD ML1-442 VEE3 F6TF-12A650-KD
1996 5.0L E4OD ML1-442 VEE4 F6TF-12A650-KE
1996 5.0L E4OD ML1-442 VEE5 F6TF-12A650-KF
1996 5.0L E4OD ML1-442 WAX0 F6TF-12A650-LA
1996 5.0L E4OD ML1-442 WAX1 F6TF-12A650-LB
1996 5.0L E4OD ML1-442 WAX2 F6TF-12A650-LC
1996 5.0L E4OD ML1-442 WAX3 F6TF-12A650-LD
1996 5.0L E4OD ML1-442 WAX4 F6TF-12A650-LE
1996 5.0L E4OD ML1-442 WAX5 F6TF-12A650-LF
also, it could just be that your computer has failed. you could visually inspect for any burnt capacitors. if you search you'll find a bunch of posts about it. but, it could still look fine and be faulty. you can search hollanderparts.com or car-part.com for one out of a junk yard. or on ebay if you're lucky.
Charlie don't surf..
'92 Ford Bronco XLT
As advised check your PCM..The 5.8 would have used a different one than the 5.0 so if the number on yours don't match up to what's on the list that is likely your problem..
Out of curiosity, did it have those codes from the get go or did the just show up one day?
Thanks dash-cam.
If I'm understanding you, what I need to do is make sure the PCM matches the engine and transmission combination. I can buy any one of the PCMs you list from fs1inc.com for around $250. Does it matter which one I get? If it does, what would determine the particular code I should look for?
jermil01,
I bought the Bronco in '17 and titled and licensed it at my cabin, which has minimal emissions requirements.
Once we sold the cabin, we brought it back into town and when the license renewal came up, I started chasing everything needed to get it to pass inspection.
sorry, but i have no idea. you might try calling them and asking.
you might also try reaching out to some of these guys.
