Yo Ross,
Hope this helps:
"CAUTION: Installation of the rear wheel bearing or inner wheel bearing oil seal assembly without the proper tool may result in a bearing or seal failure. If inner wheel bearing oil seal becomes cocked in the bore during installation, remove inner wheel bearing oil seal and install a new inner wheel bearing oil seal.
Lubricate the new rear wheel bearing with rear axle lubricant and install the rear wheel bearing into the housing bore using Axle Wheel Bearing Replacer T83T-1225-B."
Read more in 1996 Bronco/F Series Workshop Manual @
Hope this helps:
1996 Bronco/F-Series
www.diesel-dave.com
