1 - 2 of 2 Posts
I just finished installing the dbl borg steering shaft on my 78 Bronco. The steering is now much tighter. Between the rag joint and the OE upper U joint, there was quite a bit of play.
The shaft seems to be a quality piece, but the install instructions were confusing, to say the least. I ended up cutting the hollow shaft down to about 1/2 its original length. This same shaft must also fit the 3/4 and 1 tons, hence the LONG shaft. Total time was about 2 hours, taking my time, and dropping tools under the truck, and having to climb out of the engine compartment, to retrieve them.
yo
Good info! thanks:thumbup
1 - 2 of 2 Posts
