Hey Everyone,
Not necessarily new to FSB or Broncos, but never really active with FSB.. till now.
I have been modding a 73 bronco for over 23 years now.. A little bit every year (in Avatar).
I have had 5 Broncos so far, all FSB, except for aforementioned.
I am about to start a major swap project and mod with my 96 XLT 5.8
Interior 80% dyed to Black, except dash (argh...) :banghead, carpet replaced (blk), 1\2 headliner in blk suede, stock seats reupholstered in Carbon fiber marine vinyl, pretty stock otherwise, except 200 amp alt, K&N Filter, Kool flow water pump, Mean Green starter, MSD ignition, and wires. Stereo is upgraded to Pioneer head unit and speakers, with more waiting... (amps\subs..) Also have 1\4 steel front and rear bumpers (need sanded, painted, and installed) HID replacement front lights still in box, Chrome brush guard and rear light cages (need to stripped an painted black)
AODE is clunking, so going out..
Sooo..... Just purchased salvage 96 Bronco with Superlift 6 suspension lift, with Superunner steering, 6'inch lift springs, 4.86 gears, TruTrac's front and rear, , M\T wheels and BFG 35's, and a recently rebuilt HD AODE. I think you see where this going...
Both are burgundy, although the salvage vehicle is a 5.0 and was hit on rear drivers side; enough to break the leaf spring clips (hopefully the TruTrac' is good?)
will post some pics hopefully later
Yo oldschoolbronco,
Welcome Home! Great to have you here with your Bronco knowledge.
As soon as possible, find out if speed control, if equipped, recall work completed by a dealership. Call local dealer or register and view status @ https://owner.ford.com; or @ https://vinrcl.safercar.gov/vin/ ... have VIN ready.
To confirm current status, use this guide by jowens1126 @ https://www.fullsizebronco.com/forum/23-technical-write-ups/457065-93-94-96-cruise-control-recalls-repair.html#post6530073
Note that the 93 recall is different than the 94-96 recall.
BTW, 96 was built with E4OD that has 20 pan bolts:
For any Bronco questions or to chat about it's planned modifications, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as 78 - 96 Build Forum....Builds only ( (30 posts required) or Bronco and Ford Parts/Accessories (75 posts required to view).
Forum FAQs @ https://www.fullsizebronco.com/forum/21-noobie-bronco-tech-questions-flame-free-zone/165569-common-replies-faqs.html ... includes for example:
How to Post Pics @ https://www.fullsizebronco.com/forum/19-suggestions-feedback-site-help/6204-how-post-pictures.html
How to use Search @ https://www.fullsizebronco.com/forum/19-suggestions-feedback-site-help/62157-how-use-search-advanced.html
Baba Looey's Favorite FSB Links (lots and lots of tech links) @ https://www.fullsizebronco.com/forum/21-noobie-bronco-tech-questions-flame-free-zone/131287-baba-looeys-favorite-fsb-links-lots-lots-tech-links.html
96 Bronco-F-Series Workshop Manual (PARTIAL) via 1996 Bronco/F-Series Workshop Manual
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ https://www.fleet.ford.com/partsandservice/owner-manuals/
96 Bronco Dealer Brochure @ https://www.supermotors.net/registry/3549/15947-2 ... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ 1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
Free registration for some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Register to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ http://owner.ford.com .
VOTE in our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests @ https://www.fullsizebronco.com/forum/27-f-o-t-m-voting/
Contests will be held in JANUARY, MARCH, MAY, JULY, & SEPTEMBER. Each month in-between will be used for nominating contestants to run in the following Month.
Then get ready for the Full-Size of the Year (F.O.T.Y.) Contest⚠
Al
Addicted to Junk
Welcome back home!
You've done good with the mods so far, and that donor bronco is a goldmine of suspension and axle goodies.
You'll have to inspect the rear axle and diff to know if the rear tru-trac is still okay. Unless the bronco took a direct hit to the wheel, pushing the axle shaft inwards, I'd wager the tru-trac will be okay.
Welcome back home!
The wheel was slightly damaged and tire punctured, (replace yesterday)
will not know if tru-trac is good till opening up...
Keeping my fingers crossed.
thx
