1 - 3 of 3 Posts
less than 10000 miles on it and shifts perfect. it just takes it a while to go into drive once u move the shifter. its only slow to shift into forward gears. some times its 3 seconds when it messes up and sometimes it never goes in until i turn it off give it a sec and restart it.
please help me
thank u, justin
What year of Bronco do you have? Thease newer transmissions are controled buy the computor like my 95 has the E40d. I would check the Gear Position Sensor. You could have a bad contact. Some times good, some times bad! Just like an old flash light. You know, like that one that gets brighter when you shake it!
Roller rockers are gay
ok, 2nd fawkin noob post that say's "help me". dude we know nothing of what you're working on. we assume a bronco, but we have no clue. is it a vega?
give us your year, make, model, engine size, and which trans you have and we can much better help you. the search button is your friend.
<<<<<<<fill in your bronco info over there. there is a sticky thread here that will help you determine which trans you have.
1 - 3 of 3 Posts
