1 - 8 of 8 Posts
I ordered new body mounts from LMC and they are different sizes than the stock body mounts. It didnt come with any kind of diagrams showing which goes where, so my question is, how do I know which ones go where if they arent the same as what the stock ones look like? Anybody have a diagram or something?
Thanks
Travis
Lets see some pictures. Your old ones are probably pretty squashed and will seem much wider and shorter than the new ones.
When I did them on my F100, they were all the same size.
I know when I bought a full kit from them, I had to use LMC's catolog and match up the part numbers on the mounts with the part numbers in the catolog. There's also a few diagrams in the catolog. Hope this helps
formerly Nascarfreak88
i think mine came with a diagram.
I know the smaller ones go up front on the core support.
Mine was a truck and i think the other 8 (4 locations, 2 bushings on each side of the mount) were the same size.
Smaller pucks should go in the front, 6 middle ones should be the same and I believe the ones in the rear are flater but same diameter then the middle 6. If it's a Rancho kit, just call them and they'll email the instructions to you.
1 - 8 of 8 Posts
