New Work/Parts Done on the 96 EB
4722 Views 9 Replies 4 Participants Last post by  miesk5
2
Yesterday I had Midas put in the stock muffler and I had them add a stainless rolled tip.
When I got it home - I put on the new grill, headlights and headlight rings.
Also new Fuel Injectors and fuel pressure regulator.
I hear someone buys the old injectors, anyone have contact info?
I didnt get the dirt and bugs off as Im using it for a daily driver for work at a power plant right now, finally putting some miles on it.
1 - 10 of 10 Posts
yo MC,
looking good, as usual!
Did Midas use screws to mount the tip? If so, consider a heat resistant coating on the screw holes to prevent rusting...it may help extend the pipe's life span a bit. Same for muffler strap, bolts/nuts, etc.
Thank you miesk5 - No they welded it out.
Hey Question:
When I was in the grill area I took off the whole front plastic header piece (5 Radiator Grille Opening Panel Reinforcement 8A284)
and noticed a couple of OEM plugs on the drivers side outboard radiator support (8A927) they were capped off and all.
And of course I didn't take pictures.
What do you suppose they are?
As you can see I'm staying in a RV park here in Texarkana while I work during the week :)
Were they on the drivers side? Might be the outside temp probe for the overhead console.
3
yo,
As Ewgoetz mentioned;
Fender Apron, Left, Gasoline Engines
Item Part Number Description
1 33777 Nut
2 16E555 Insulator (Bronco Only)
3 — Locator, Position in Hole Provided (Part of 12A581)
4 — To LH Parking Lights
5 — To LH Air Bag Sensor
6 — To LH Headlamp
7 — To LH Turn and Park
8 12A581 Wiring Assembly
9 — To Canadian Daytime Running Lamp
10 N806972-S36MG Screw to Ground Wire Assembly
11 — To Windshield Washer Pump
12 2C279 Anti-Lock Brake System Control Module Bracket and Assembly (40 Way) (Bronco Only)
13 — To Anti-Lock Brake System Control Module
14 — To Hydraulic Unit (8-Way) (Bronco Only)
15 — To Pump Motor (4-Way) (Bronco Only)
16 N806327-S190 Screw
17 14B005 Sensor and Bracket Assembly
18 8496 Radiator Support
19 — To Intake Air Temperature Sensor
20 9A603 Air Cleaner
21 — To Mass Airflow Sensor
A — Tighten to 9-13 Nm (80-115 Lb-In)
B — Tighten to 5-7 Nm (44-62 Lb-In)
C — Tighten to 10-14 Nm (7-10 Lb-Ft)
Bronco Overhead Console Wiring & Connectors
IF THE IMAGE IS TOO SMALL, click it.
The rear-view mirror connector is WPT-584.
The temperature sensor connector is WPT-437; C131
The console connector is WPT-667.
Connector 299 is WPT-329/519.
1 12A581 Wiring Assembly
2 — Locator, Place in Hole Provided (Part of 14401)
3 N610957-S2 Screw
4 15A272 Daytime Running Lamp Module
5 — To Ambient Temperature Sensor C1316 — Ambient Temperature Sensor (Bronco Only) (Part of 14401)
7 — Front End Air Seal (Part of 01610)
8 14A624 Cap
9 14A666 Ambient Temperature Sensor Connector Cap
3 N610957-S2 Screw
8 14A624 Cap
those were the units right there.
Thanks Miesk5 = Awesome.
What does the running lamps connector do?
Oh - and I got 14.7 MPG this past two weeks going about 13 miles to work daily. So 26 miles round trip.
Just changed the injectors and Pressure Regulator. Should get better :rockon
Running lights connector, good place to wire up aftermarket running lights? Either on sidesteps or maybe a Lund Moon Visor. Do all Broncos have this?
2
yo, yw MC!
Daytime Running Lamp (DRL) System
The daytime running lamp system is designed to turn the high beam headlamps on, with a reduced light output, and without illuminating the high beam indicator lamp in the instrument panel (04320) when the following conditions exist:
The ignition switch lock cylinder (11582) is in the RUN position.
The parking brake is fully released.
The headlamp switch (11654) is in the OFF or PARK position.
and for posterity:
Before performing any lighting systems test, check that the battery is fully charged, that battery connections are clean and tight, and that burned out fuses and bulbs have been replaced. The low beam headlamps should operate correctly. If not, refer to Section 17-01. The daytime running lamp module is grounded through the low beam circuit while operating the high beam
Pin Number Circuit Circuit Function
2 — Locator (Part of 12A581)
3 15A272 Daytime Running Lamps Control
4 N610957 Screw
5 — To Ambient Temperature Sensor (Part of 12A581)
(Part of 12A581)
7 15422 Front End Air Seal
8 14666 Ambient Temperature Sensor Delete Cap
9 14A624 Cap
Removal
Remove screw retaining daytime running lamps control (15A272) to radiator support (16138).
Disconnect data link connector (14489).
Remove daytime running lamps control.
Installation
Follow removal procedures in reverse order.
Tighten retaining screw to 2.6-3.2 Nm (23-29 lb-in).
Inspection and Verification
Verify the vehicle owner's original concern by operating the daytime running lamps to duplicate the vehicle owner's concern.
Inspect to determine if one of the following mechanical or electrical concerns apply:
VISUAL INSPECTION CHART
Mechanical
Damaged headlamps
Damaged connectors
Damaged ignition switch
Damaged daytime running lamp control module
Damaged parking brake switch
Damaged headlamp switch
Damaged multi-function switch
Electrical
Open instrument panel fuse (10A)
Open power distribution box fuses (15A, 30A)
Circuitry open/shorted
the concern(s) remains after the inspection, determine the symptom(s) and proceed to the following symptom chart.
DAYTIME RUNNING LAMPS Condition Possible Source Action
Daytime Running Lamps Inoperative
Daytime running lamps control module not installed.
Open or shorted circuitry.
Damaged daytime running lamps control module.
GO to Pinpoint Test A.
High Beam Indicator Inoperative
Damaged miniature bulb.
GO to Pinpoint Test
PINPOINT TEST A: DRL MALFUNCTION OR DRL INOPERATIVE
A1 CHECK HIGH BEAM OPERATION
Key in RUN.
Parking brake fully released.
Headlamp switch OFF or in the PARK position.
Are the high beams off?
Yes GO to A3.
No GO to A2.
A2 CHECK HIGH BEAM INTENSITY
Key in RUN.
Are the high beams on at reduced intensity?
Yes System is functioning properly. No service required
No REPLACE daytime running lamps control module. RESTORE vehicle. RETEST system
A3 CHECK DAYTIME RUNNING LAMPS CONTROL MODULE INSTALLATION
Key OFF.
Headlamp switch OFF.
Check installation of daytime running lamps control module and harness connector.
Is daytime running lamps control module installed and is connector fully seated?
Yes GO to A4.
No REINSTALL daytime running lamps control module. RESTORE vehicle. RETEST system
A4 CHECK DAYTIME RUNNING LAMPS CONTROL MODULE POWER
Key OFF.
Remove daytime running lamps control module.
Check IP fuse panel fuse 17 (10A) and power distribution box fuses 3 (30A) and 5 (15A) for an open.
Replace fuse(s) if opened.
Key in RUN.
Multi-function switch in LO beam position.
Is battery voltage present at Pins 3 and 7 of daytime running lamps control module and at Pin 13 of instrument cluster connectors?
Yes GO to A5.
No SERVICE Circuit 298 (P/O), Circuit 38 (BK/O), or Circuit 640 (R/Y) for open circuit. RESTORE vehicle. RETEST system.
A5 CHECK DAYTIME RUNNING LAMPS CONTROL MODULE PIN 8
With daytime running lamps control module removed, actuate key to RUN.
Headlamp switch in the HEAD position.
Multi-function switch in the HI beam position.
Check for battery voltage at Pin 8 of the daytime running lamps control module connector.
Is battery voltage present?
Yes GO to A6.
No SERVICE open in Circuit 12 (LG/BK) between headlamps and daytime running lamps control module connector. RESTORE vehicle. RETEST system
A6 CHECK MODULE GROUND
Check resistance between Pin 6 of the daytime running lamps control module connector and a known good ground.
Is resistance 1.5 ohms or less?
Yes GO to A7.
No SERVICE open in Circuit 13 (R/BK) between headlamps and daytime running lamps control module connector. RESTORE vehicle. RETEST system.
A7 CHECK DAYTIME RUNNING LAMPS CONTROL MODULE PIN 6
Multi-function switch in the LO beam position.
Check for battery voltage at Pin 6 of the daytime running lamps control module connector.
Yes GO to A8.
A8 CHECK HIGH BEAM INDICATOR
Jumper Pin 8 to Pin 1 of the daytime running lamps control module connector.
Did high beam indicator illuminate?
YesGO to A9.
No REPLACE illumination bulb or SERVICE Circuits 932 (GY/W) or 57 (BK) for an open. RESTORE vehicle. RETEST system.
A9 CHECK PARKING BRAKE SWITCH
With daytime running lamps control module removed, actuate all accessories to the OFF position.
Check continuity of the parking brake switch between Pin 4 of the daytime running lamps control module connector and a known good ground.
Apply and release parking brake.
Is resistance less than 1.5 ohms with parking brake applied and is resistance infinite with the parking brake released?
Yes GO to A10.
No SERVICE ground connection at parking brake switch, or SERVICE Circuit 162 (LG/R) for an open or a short, or REPLACE parking brake switch. RESTORE vehicle. RETEST system.
A10 RECHECK DAYTIME RUNNING LAMPS CONTROL MODULE
Reinstall daytime running lamps control module.
Key in RUN.
Yes System is functioning properly. No service required.
No REPLACE daytime running lamps control module. RESTORE vehicle. RETEST system.
Daytime Running Lamps, F-Series and Bronco
all from 1996 F-150, F-250, F-350, F-Super Duty, Chassis Cab and Motorhome Chassis, and Bronco (Canadian Vehicles Only) Workshop Manual
Yo,
My 96XL, bought new doesn't have the DRL Module, but has the connector.
For aftermarket lighting; see my site under Electrical, Light - Brake, Turn & Stop, Dome, Fog, Rock, Under-Hood, etc
such as:
Auxiliary/Off-Road Installation & Wiring Tips
Source: by Ian L (stangmata, stangmata50l, Bronco) at FSB
Buy a quality switch and AVOID any made in China; had one fall apart in my hands recently.
Yo,
Ford says in 96 Owner's Guide; "...Canadian vehicles only..."
If you don't have the Guide for the 96, get it here on-line for free by Hiller Ford
such as:
1 - 10 of 10 Posts
