I have a fairly new engine but I am losing oil somewhere. It is a carbed 351 with holley carb and edelbrock intake. PCV is on the passenger side and goes to the carb. Drivers side is a vented oil filler that plugs into the valve cover.
I changed my oil the other day and it was low. So low I noticed valve noise when it was idling, checked the oil it was low so I changed it. I am a bad owner and I was not regularly checking the oil, (hopefully the few minutes of valve noise did not hurt anything) but who checks the oil when it is a fairly new engine and it is not blowing smoke or leaking out on the ground.
So where is my oil going? I am not leaking on the ground. My No. 4 spark plug is blacker than the rest but not even close to being fouled. The engine is loosing some oil from the PVC and oil filler, but really how much could that be, it is not showing up on the ground.
I sometimes get a small puff of smoke on start up, but I typically pump the gas twice and pull the choke. I would guess it is unburnt gas fumes since the PO removed my cat.
Could it be the PCV system causing the blackened No. 4 plug? The PO removed my emmisions stuff. I just have a 10 inch hose with PVC valve running valve cover to the carb vaccum.
Would an oil seperator help with the blacken no. 4 plug? Maybe I am slowly loosing than much oil out the PVC and oil filler when I run hard????
